* | cpukit: Remove unused includes | Kinsey Moore | 2023-10-13 | 1 | -1/+0 |
* | score/src/[n-s]*.c: Change license to BSD-2 | Joel Sherrill | 2022-02-28 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | Remove superfluous <rtems/score/wkspace.h> includes | Sebastian Huber | 2021-04-20 | 1 | -1/+0 |
* | score: Canonicalize Doxygen @file comments | Sebastian Huber | 2020-12-02 | 1 | -1/+2 |
| | | | | | | Use common phrases for the file brief descriptions. Update #3706. | ||||
* | doxygen: Switch @brief and @ingroup | Sebastian Huber | 2020-04-28 | 1 | -1/+2 |
| | | | | This order change fixes the Latex documentation build via Doxygen. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | score: Fix objects node initialization | Sebastian Huber | 2020-01-02 | 1 | -0/+1 |
| | | | | | | | The objects node is statically initialized to one. Clear the node field before it is set. Update #3621. | ||||
* | doxygen: Rename Score* groups in RTEMSScore* | Sebastian Huber | 2019-04-04 | 1 | -1/+1 |
| | | | | Update #3706 | ||||
* | score: Remove superfluous include from chainimpl.h | Sebastian Huber | 2019-01-07 | 1 | -0/+1 |
* | score: Static Objects_Information initialization | Sebastian Huber | 2018-12-14 | 1 | -66/+33 |
| | | | | | | | | | | | Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621. | ||||
* | score: Remove Objects_Information::auto_extend | Sebastian Huber | 2018-12-14 | 1 | -12/+13 |
| | | | | | | | Use Objects_Information::objects_per_block to provide this information. Add and use _Objects_Is_auto_extend(). Update #3621. | ||||
* | score: Remove Objects_Information::the_api | Sebastian Huber | 2018-12-07 | 1 | -2/+6 |
| | | | | | | | Remove Objects_Information::the_class. This information is already contained in Objects_Information::maximum_id. Update #3621. | ||||
* | score: Remove Objects_Information::maximum | Sebastian Huber | 2018-12-07 | 1 | -14/+3 |
| | | | | | | | This information is already present in Objects_Information::maximum_id. Add and use _Objects_Get_maximum_index(). Update #3621. | ||||
* | score: Optimize object lookup | Sebastian Huber | 2018-12-07 | 1 | -15/+2 |
| | | | | | | | | | | | | | | | | Use the maximum ID for the ID to object translation. Using the maximum ID gets rid of an additional load from the object information in _Objects_Get(). In addition, object lookups fail for every ID in case the object information is cleared to zero. This makes it a bit more robust during system startup (see new tests in spconfig02). The local table no longer needs a NULL pointer entry at array index zero. Adjust all the object iteration loops accordingly. Remove Objects_Information::minimum_id since it contains only redundant information. Add _Objects_Get_minimum_id() to get the minimum ID. Update #3621. | ||||
* | score: Rename Objects_Information::allocation_size | Sebastian Huber | 2018-12-07 | 1 | -1/+1 |
| | | | | | | | | Rename Objects_Information::allocation_size in Objects_Information::objects_per_block. Adjust integer types in _Objects_Shrink_information() and _Objects_Free(). Update #3621. | ||||
* | score: Rename Objects_Information::size | Sebastian Huber | 2018-12-07 | 1 | -2/+2 |
| | | | | | | | | Rename Objects_Information::size to Objects_Information::object_size. Change its type from size_t to uint16_t and move it to reduce the size of Objects_Information. Update #3621. | ||||
* | score: Remove Objects_Information::is_string | Sebastian Huber | 2018-12-07 | 1 | -3/+1 |
| | | | | | | Use Objects_Information::name_length to store this information. Update #3621. | ||||
* | Remove RTEMS_SCORE_OBJECT_ENABLE_STRING_NAMES | Sebastian Huber | 2018-10-29 | 1 | -3/+1 |
| | | | | | | | | | Enable support for string objects names unconditionally. Add const qualifier throughout. Split _Objects_Namespace_remove() into _Objects_Namespace_remove_u32() and _Objects_Namespace_remove_string() to avoid an unnecessary dependency on _Workspace_Free(). Update #2514. | ||||
* | score: Introduce _Internal_error() | Sebastian Huber | 2016-12-12 | 1 | -4/+1 |
* | score: Remove fatal is internal indicator | Sebastian Huber | 2016-12-09 | 1 | -1/+0 |
| | | | | | | | | | The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825. | ||||
* | score: Simplify _Objects_Initialize_information() | Sebastian Huber | 2016-04-21 | 1 | -2/+1 |
| | | | | | | Remove unused supports_global parameter. Convert _Objects_Initialize_information() to a macro to avoid use of RTEMS_MULTIPROCESSING define for each caller. | ||||
* | score: Use red-black tree for active global objects | Sebastian Huber | 2016-04-06 | 1 | -16/+2 |
| | | | | | | | Use a red-black tree to lookup active global objects by identifier or name. Update #2555. | ||||
* | score: Rename _Internal_error_Occurred() | Sebastian Huber | 2014-02-21 | 1 | -1/+1 |
| | | | | Rename _Internal_error_Occurred() into _Terminate(). | ||||
* | score: Create object implementation header | Sebastian Huber | 2013-07-26 | 1 | -9/+3 |
| | | | | | | Move implementation specific parts of object.h and object.inl into new header file objectimpl.h. The object.h contains now only the application visible API. | ||||
* | score: Create chain implementation header | Sebastian Huber | 2013-07-22 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of chain.h and chain.inl into new header file chainimpl.h. The chain.h contains now only the application visible API. | ||||
* | score misc: Clean up Doxygen (GCI 2012) | Alex Ivanov | 2012-11-28 | 1 | -20/+7 |
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208 | ||||
* | score: New macros and functions | Sebastian Huber | 2012-04-11 | 1 | -4/+3 |
| | | | | | | | | | | New macros o _Objects_Maximum_per_allocation(), o rtems_resource_is_unlimited(), and o rtems_resource_maximum_per_allocation(). New function o _Objects_Is_unlimited(). | ||||
* | 2011-11-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-11-30 | 1 | -1/+0 |
| | | | | | * score/src/objectinitializeinformation.c (_Objects_Initialize_information): Remove unused var "name_length". | ||||
* | 2011-11-29 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-11-29 | 1 | -14/+8 |
| | | | | | | | PR 1967/cpukit * score/include/rtems/score/object.h, score/src/objectinitializeinformation.c: Remove OBJECTS_NAME_ALIGNMENT and uses. | ||||
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | ||||
* | Remove white-spaces. | Ralf Corsepius | 2011-05-24 | 1 | -1/+1 |
* | 2011-03-08 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-08 | 1 | -2/+2 |
| | | | | | | * score/src/objectinitializeinformation.c: Reverse sense of conditional and improve comment. Comment was right but brief, conditional was backwards. | ||||
* | 2011-02-11 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-02-11 | 1 | -4/+9 |
| | | | | | | | | * rtems/src/semtranslatereturncode.c, score/include/rtems/score/coremutex.h, score/src/coremutexsurrender.c, score/src/objectinitializeinformation.c: Disable code not reachable when POSIX is not enabled. | ||||
* | 2010-08-09 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | 2010-08-10 | 1 | -1/+1 |
| | | | | | | | | | | PR 1660/filesystem * libfs/src/pipe/fifo.c, libfs/src/pipe/pipe.h: Changed int pipe_release to void pipe_release. * libfs/src/imfs/imfs_fifo.c: Corresponding change to IMFS_fifo_close since pipe_release does not return any error. * libfs/src/imfs/imfs_initsupp.c: Changes to improve IMFS_determine_bytes_per_block | ||||
* | 2010-03-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-10 | 1 | -0/+11 |
| | | | | | | * score/include/rtems/score/interr.h, score/src/objectinitializeinformation.c: Add new fatal error for configuring unlimited and maximum of 0. | ||||
* | 2010-01-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-01-19 | 1 | -57/+36 |
| | | | | | | | Coverity Id 5 * score/src/objectinitializeinformation.c: Do not modify maximum parameter. Clean up and simplify code. This should help the Coverity path analysis to avoid reporting issues. | ||||
* | 2009-09-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-09-11 | 1 | -0/+2 |
| | | | | | | | | | | | * score/include/rtems/score/object.h, score/inline/rtems/score/object.inl, score/src/objectgetnameasstring.c, score/src/objectidtoname.c, score/src/objectinitializeinformation.c, score/src/objectnamespaceremove.c, score/src/objectnametoidstring.c, score/src/objectsetname.c, score/src/thread.c, score/src/threadcreateidle.c: Disable object string name support when POSIX is not enabled. | ||||
* | Eliminate TRUE/FALSE. | Ralf Corsepius | 2008-12-22 | 1 | -3/+3 |
* | Convert to "bool". | Ralf Corsepius | 2008-09-04 | 1 | -3/+3 |
* | 2008-01-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-01-24 | 1 | -1/+0 |
| | | | | | | | | * score/include/rtems/score/object.h, score/src/objectextendinformation.c, score/src/objectinitializeinformation.c, score/src/objectshrinkinformation.c: Eliminate name_table since it is not used. | ||||
* | 2007-12-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-19 | 1 | -4/+5 |
| | | | | | | | | | | | * libcsupport/Makefile.am, libcsupport/include/rtems/malloc.h, libcsupport/src/free.c, libcsupport/src/malloc.c, libcsupport/src/malloc_p.h, libcsupport/src/malloc_report_statistics_plugin.c, libmisc/shell/shell.c, libmisc/shell/shell.h, score/src/objectinitializeinformation.c: Add posix_memalign. Split out management of deferred frees to subroutines. * libcsupport/src/malloc_deferred.c, libcsupport/src/posix_memalign.c: New files. | ||||
* | 2005-02-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-10 | 1 | -1/+1 |
| | | | | | | | | | | | | PR 753/rtems * score/include/rtems/score/object.h, score/src/objectinitializeinformation.c: Configured number of objects needs to be of a type with more bits than Objects_Maximum to support configuring unlimited objects. The type for configuring the maximum number of objects should probably always be the same fundamental type as Object Id. For 16-bit Id configurations, the constant OBJECTS_UNLIMITED_OBJECTS was changed to 0x8000 to move in this direction. | ||||
* | Include config.h. | Ralf Corsepius | 2005-01-27 | 1 | -0/+4 |
* | 2004-11-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-11-29 | 1 | -2/+2 |
| | | | | | | | | | | | | * libcsupport/src/mallocfreespace.c, rtems/Makefile.am, rtems/include/rtems/rtems/region.h, score/Makefile.am, score/include/rtems/score/heap.h, score/src/heapgetinfo.c: Add capability to return information about just the free blocks in a region or heap. Also changed the semantics of free space available to be the largest block of memory that can be allocated. * rtems/src/regiongetfreeinfo.c, score/src/heapgetfreeinfo.c: New files. : score/include/rtems/score/object.h, score/src/objectinitializeinformation.c: Remove warning. | ||||
* | 2004-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-11-01 | 1 | -2/+2 |
| | | | | | | | | * score/include/rtems/score/object.h, score/src/object.c, score/src/objectallocatebyindex.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectinitializeinformation.c: Fix bugs in previous commit. Now compiles. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-18 | 1 | -4/+4 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-17 | 1 | -10/+10 |
* | 2004-04-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-29 | 1 | -7/+7 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c, score/src/coretodtickle.c, score/src/coretodtoseconds.c, score/src/coretodvalidate.c, score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapsizeofuserarea.c, score/src/interr.c, score/src/iterateoverthreads.c, score/src/mpci.c, score/src/object.c, score/src/objectallocate.c, score/src/objectallocatebyindex.c, score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetbyindex.c, score/src/objectgetisr.c, score/src/objectgetnoprotection.c, score/src/objectidtoname.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectshrinkinformation.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadget.c, score/src/threadidlebody.c, score/src/threadinitialize.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueuepriority.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadreset.c, score/src/threadrestart.c, score/src/threadsettransient.c, score/src/threadstackallocate.c, score/src/threadstart.c, score/src/userext.c, score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using c99 fixed size types. |
