path: root/cpukit/score/src/objectallocatestatic.c (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-2/+5
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Split up objects allocationSebastian Huber2020-02-121-0/+44
Split up the different objects allocation methods into separate functions. This helps to avoid a dependency on the workspace in case no objects or a static set of objects is configured. Change license to BSD-2-Clause according to file histories. Update #3053. Update #3835.
