The uniprocessor schedulers had some special case logic for the
PRIORITY_PSEUDO_ISR priority. Tasks with a priority of PRIORITY_PSEUDO_ISR
were allowed to preempt a not preemptible task. If other higher priority task
are made ready while a PRIORITY_PSEUDO_ISR task preempts a not preemptible
task, then the other tasks run before the not preemptible task. This made the
RTEMS_NO_PREEMPT mode ineffective.
Remove the PRIORITY_PSEUDO_ISR special case logic. This simplifies the
uniprocessor schedulers. Move the uniprocessor-specific scheduler support to
the new header file <rtems/score/scheduleruniimpl.h>.
Close #2365.
Updates #3053.
This patch set replaces the CPU budget algorithm enumeration with a set of CPU
budget operations which implement a particular CPU budget algorithm. This
helps to hide the CPU budget algorithm implementation details from the general
thread handling. The CPU budget callouts are turned into CPU budget
operations. This slightly reduces the size of the thread control block.
All schedulers used the default scheduler tick implementation. The tick
scheduler operation is removed and the CPU budget operations are directly used
in _Watchdog_Tick() if the executing thread uses a CPU budget algorithm. This
is performance improvement for all threads which do not use a CPU budget
algorithm (default behaviour).
Close the thread object if a thread create extension fails. Also call
the delete extension to avoid resource leaks in early extensions if a
late extension fails.
Close #4270.
Use the type safe _Objects_Open_u32() instead. Return the object
identifier to enforce a common usage pattern.
Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Place idle and MPCI stacks into extra linker sections. This can be
optionally used by applications to control the placement of the stacks.
Update #3835.
Move thread stack allocation to caller side of _Thread_Initialize().
Update #3835.
Add the Thread_Configuration structure to reduce the parameter count of
_Thread_Initialize(). This makes it easier to add more parameters in
the future. It simplifies the code generation since most architectures
do not have that many registers available for function parameters.
Update #3835.
Replace the user MPCI configuration table with a system provided
_MPCI_Configuration.
Update #3735.
Update #3706
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
Move thread state for _Thread_queue_Enqueue() to the thread queue
context. This reduces the parameter count of _Thread_queue_Enqueue()
from five to four (ARM for example has only four function parameter
registers). Since the thread state is used after several function calls
inside _Thread_queue_Enqueue() this parameter was saved on the stack
previously.
Delete unused _Thread_queue_Enqueue() and rename
_Thread_queue_Enqueue_critical() to _Thread_queue_Enqueue().
Replace the expected thread dispatch disable level with a thread queue
enqueue callout. This enables the use of _Thread_Dispatch_direct() in
the thread queue enqueue procedure. This avoids impossible exection
paths, e.g. Per_CPU_Control::dispatch_necessary is always true.
Avoid use of processor index 0 which may have no scheduler assigned.
Avoid direct access to thread internal data fields.
Introduce Thread_queue_Lock_context to contain the context necessary for
thread queue lock and thread wait lock acquire/release operations to
reduce the Thread_Control size.
Clock disciplines may be WATCHDOG_RELATIVE, WATCHDOG_ABSOLUTE,
or WATCHDOG_NO_TIMEOUT. A discipline of WATCHDOG_RELATIVE with
a timeout of WATCHDOG_NO_TIMEOUT is equivalent to a discipline
of WATCHDOG_NO_TIMEOUT.
updates #2732
Move the safety check performed by
_CORE_mutex_Check_dispatch_for_seize() out of the performance critical
path and generalize it. Blocking on a thread queue with an unexpected
thread dispatch disabled level is illegal in all system states.
Add the expected thread dispatch disable level (which may be 1 or 2
depending on the operation) to Thread_queue_Context and use it in
_Thread_queue_Enqueue_critical().
Add _Thread_queue_Context_set_MP_callout() to simplify
_Thread_queue_Context_initialize(). This makes it possible to more
easily add additional fields to Thread_queue_Context.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Close #2720.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
Delete unused parameter.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Update #2555.
Update #2555.
Update #2703.
This field was only by the monitor in non-multiprocessing
configurations. Add new field Thread_Wait_information::remote_id in
multiprocessing configurations and use it for the remote procedure call
thread queue.
Add _Thread_Wait_get_id() to obtain the object identifier for debug and
system information tools. Ensure the object layout via static asserts.
Add test cases to sptests/spthreadq01.
Remove the Thread_queue_Queue::operations field to reduce the size of
this structure. Add a thread queue operations parameter to the
_Thread_queue_First(), _Thread_queue_First_locked(),
_Thread_queue_Enqueue(), _Thread_queue_Dequeue() and
_Thread_queue_Flush() functions. This is a preparation patch to reduce
the size of several synchronization objects.
Update #2555.
Delete SCORE_INIT. This finally removes the
some.h:
#ifndef SOME_XYZ_EXTERN
#define SOME_XYZ_EXTERN extern
#endif
SOME_XYZ_EXTERN type xyz;
some_xyz.c:
#include <some.h>
pattern in favour of
some.h:
extern type xyz;
some_xyz.c
#include <some.h>
type xyz;
Update #2559.
Update #2408.
Assignment is superfluous due to later call to _Thread_queue_Enqueue().
Update due to API changes introduced by
ccd54344d904b657123e4e4ba795a32212382be2.
Update #2514.
Rename _CORE_semaphore_Seize_isr_disable() to _CORE_semaphore_Seize().
Update #2273.
Use a parameter for _Thread_queue_Enqueue() instead to reduce memory
usage.
Move the complete thread queue enqueue procedure into
_Thread_queue_Enqueue_critical(). It is possible to use the thread
queue lock to protect state of the object embedding the thread queue.
This enables per object fine grained locking in the future.
Delete _Thread_queue_Enter_critical_section().
Update #2273.
Remove thread queue parameter from _Thread_queue_Extract() since the
current thread queue is stored in the thread control block.
