Fix rtems_configuration_get_interrupt_stack_size() for some code models.
The _ISR_Stack_size symbol has an arbitrary absolute address and may not
be representable in the code model used by the compiler.
Update #4953.
Updates #3053.
The _ISR_Handler_initialization() does not touch the _ISR_Vector_table[]. Move
the definition of _ISR_Vector_table[] to a separate file.
Change license to BSD-2-Clause according to file history and re-licensing
agreement.
Update #3053.
This variable is actually contained in _Per_CPU_Information[] which is already
zero initialized.
Remove superfluous includes.
This CPU port macro was not used. Since the _ISR_Vector_table[] is statically
allocated, CPU ports could initialize this table in _CPU_Initialize() if
necessary. Remove _CPU_Initialize_vectors() to simplify the CPU port
interface.
Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3706
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
The configured interrupt stack size (CONFIGURE_INTERRUPT_STACK_SIZE) is
checked against the minimum task stack size. The minium tasks task
stack size is also a configuration option
(CONFIGURE_MINIMUM_TASK_STACK_SIZE). So, this check does not really
help in case of configuration errors. In addition, the interrupt stack
is also re-used as the initialization stack in most BSPs. It is
probably better to use a stack checker to detect problems.
Update #3459.
Statically initialize the interrupt stack area
(_Configuration_Interrupt_stack_area_begin,
_Configuration_Interrupt_stack_area_end, and
_Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the
interrupt stack area in a special section ".rtemsstack.interrupt". Let
BSPs define the optimal placement of this section in their linker
command files (e.g. in a fast on-chip memory).
This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and
CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the
low level initialization code has all information available via global
symbols.
This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define
superfluous, since the interrupt stacks are allocated by confdefs.h for
all architectures. There is no need for BSP-specific linker command
file magic (except the section placement), see previous ARM linker
command file as a bad example.
Remove _CPU_Install_interrupt_stack(). Initialize the hardware
interrupt stack in _CPU_Initialize() if necessary (e.g.
m68k_install_interrupt_stack()).
The optional _CPU_Interrupt_stack_setup() is still useful to customize
the registration of the interrupt stack area in the per-CPU information.
The initialization stack can reuse the interrupt stack, since
* interrupts are disabled during the sequential system initialization,
and
* the boot_card() function does not return.
This stack resuse saves memory.
Changes per architecture:
arm:
* Mostly replace the linker symbol based configuration of stacks with
the standard <rtems/confdefs.h> configuration via
CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND
mode stack is still defined via linker symbols. These modes are
rarely used in applications and the default values provided by the
BSP should be sufficient in most cases.
* Remove the bsp_processor_count linker symbol hack used for the SMP
support. This is possible since the interrupt stack area is now
allocated by the linker and not allocated from the heap. This makes
some configure.ac stuff obsolete. Remove the now superfluous BSP
variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp.
bfin:
* Remove unused magic linker command file allocation of initialization
stack. Maybe a previous linker command file copy and paste problem?
In the start.S the initialization stack is set to a hard coded value.
lm32, m32c, mips, nios2, riscv, sh, v850:
* Remove magic linker command file allocation of initialization stack.
Reuse interrupt stack for initialization stack.
m68k:
powerpc:
* Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt
stack on BSPs using the shared linkcmds.base (replacement for
REGION_RWEXTRA).
sparc:
* Remove the hard coded initialization stack. Use the interrupt stack
for the initialization stack on the boot processor. This saves
16KiB of RAM.
Update #3459.
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
Use "cpu" for an arbitrary Per_CPU_Control variable.
Use "cpu_self" for the Per_CPU_Control of the current processor.
Use "cpu_index" for an arbitrary processor index.
Use "cpu_index_self" for the processor index of the current processor.
Use "cpu_count" for the processor count obtained via
_SMP_Get_processor_count().
Use "cpu_max" for the processor maximum obtained by
rtems_configuration_get_maximum_processors().
Rename _Internal_error_Occurred() into _Terminate().
Move SMP interrupt stack initialization for secondary processors from
_SMP_Handler_initialize() to _ISR_Handler_initialization() to avoid code
duplication. Apply _CPU_Interrupt_stack_setup() to all interrupt
stacks.
Move implementation specific parts of stack.h and stack.inl into new
header file stackimpl.h. The stack.h contains now only the application
visible API.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7985215
PR 1876
* score/Makefile.am, score/include/rtems/score/isr.h, score/src/isr.c,
score/src/smp.c, score/src/smplock.c, score/src/threaddispatch.c,
score/src/threaddispatchdisablelevel.c: Add smp isr support.
* score/src/isrsmp.c: New file.
PR 1733/cpukit
* score/src/isr.c: If target architecture does nto require stack
initialization, then do not perform adjustment.
PR 1680/cpukit
* score/src/isr.c: Correct initialization of _CPU_Interrupt_stack_high
to properly do the alignment. This most likely only would have caused
a propblem on CPUs where the stack grows down and have strict
alignment.
PR 1573/cpukit
* configure.ac, posix/src/killinfo.c,
posix/src/psignalunblockthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadkill.c, posix/src/pthreadsigmask.c,
rtems/src/signalsend.c, rtems/src/taskmode.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/context.h, score/include/rtems/score/isr.h,
score/include/rtems/score/thread.h, score/src/isr.c,
score/src/isrthreaddispatch.c, score/src/thread.c,
score/src/threaddispatch.c, score/src/threadloadenv.c: Add a per cpu
data structure which contains the information required by RTEMS for
each CPU core. This encapsulates information such as thread
executing, heir, idle and dispatch needed.
* score/include/rtems/score/percpu.h, score/src/percpu.c: New files.
* score/src/isr.c: Check if CPU defined _CPU_Interrupt_stack_setup()
macro hook for setting up the interrupt stack (alignment, reserving
space etc.) after the framework allocates it.
* itron/include/rtems/itron/itronapi.h, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-mpci.c,
posix/include/rtems/posix/config.h,
posix/include/rtems/posix/posixapi.h,
rtems/include/rtems/rtems/config.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/src/taskinitusers.c,
sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/src/exinit.c, sapi/src/itronapi.c,
sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/isr.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Eliminate pointers to API configuration tables
in the main configuration table. Reference the main configuration
table and the API configuration tables directly using the confdefs.h
version rather than obtaining a pointer to it. This eliminated some
variables, a potential fatal error, some unnecessary default
configuration structures. Overall, about a 4.5% reduction in the code
size for minimum and hello on the SPARC.
* posix/include/rtems/posix/pthread.h, posix/src/pthread.c,
posix/src/pthreadcreate.c, rtems/include/rtems.h, rtems/src/attr.c,
score/inline/rtems/score/stack.inl, score/src/isr.c,
score/src/mpci.c, score/src/threadcreateidle.c,
score/src/threadinitialize.c, score/src/threadstackallocate.c: Add
ability for application to configure minimum stack size. Add
RTEMS_CONFIGURED_MINIMUM_STACK_SIZE constant so user can clearly
indicate they want the configured as opposed to the recommended
minimum stack size.
* score/include/rtems/score/isr.h, score/src/isr.c: Use
CPU_SIMPLE_VECTORED_INTERRUPTS porting parameter to avoid allocating
memory for vector table.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
score/include/rtems/system.h, score/src/isr.c: Move
interrupt_stack_size field from CPU Table to Configuration Table.
Eliminate CPU Table from all ports. Delete references to CPU Table in
all forms.
* src/isr.c: Allocate the _ISR_Vector_table all the time not just when
we are allocating an interrupt stack.
* include/rtems/score/isr.h, src/isr.c: Allocate it from the
workspace rather than explicitly declaring it. This allows
the size to be a non-constant from the perspective of score/cpu.
like signal dispatching.
