path: root/cpukit/score/src/interr.c (follow)
* score/src/[a-m]*.c: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Canonicalize _CPU_Fatal_halt()Sebastian Huber2021-07-281-3/+1
| | | | | | | | Move _CPU_Fatal_halt() declaration to <rtems/score/cpuimpl.h> and make sure it is a proper declaration of a function which does not return. Fix the type of the error code. If necessary, add the implementation to cpu.c. Implementing _CPU_Fatal_halt() as a function makes it possible to wrap this function for example to fully test _Terminate().
* score: Remove _Internal_errors_What_happenedSebastian Huber2021-07-281-10/+1
| | | | | | | | | | Users have access to the fatal error source and code though the fatal error extension. The user-specific fatal error handling should be done in statically initialized fatal error handlers. The _Internal_errors_What_happened was updated after the fatal error extension. In addition, there was no API to get the information stored in _Internal_errors_What_happened. In SMP configurations, this object could contain a mix of different fatal errors. Remove this object to save some bytes of storage.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+3
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* doxygen: Switch @brief and @ingroupSebastian Huber2020-04-281-1/+2
| | | | This order change fixes the Latex documentation build via Doxygen.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* score: Introduce _Internal_error()Sebastian Huber2016-12-121-0/+5
* score: Remove fatal is internal indicatorSebastian Huber2016-12-091-7/+5
| | | | | | | | | The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825.
* score: Postpone SMP shutdown in _Terminate()Sebastian Huber2016-07-061-2/+2
| | | | | This enables fatal extensions to continue program execution after some fatal errors.
* score: Do not disable ISR in _Terminate()Sebastian Huber2016-07-061-6/+0
| | | | | | | This partially reverts 38ee75853f674977609bd078c69fb53420afdd08. Let the calling context decide if interrupts must be disabled or not. The goal is to enable fatal extensions to continue program execution after some fatal errors.
* score: Rename _ISR_Disable_without_giant()Sebastian Huber2016-05-201-1/+1
| | | | | | | | | Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename _ISR_Enable_without_giant() into _ISR_Local_enable(). This is a preparation to remove the Giant lock. Update #2555.
* Let CPU/BSP Fatal handler have access to sourceDaniel Hellstrom2014-09-101-1/+1
| | | | | | | | | Without the source the error code does not say that much. Let it be up to the CPU/BSP to determine the error code reported on fatal shutdown. This patch does not change the current behaviour, just adds the option to handle the source of the fatal halt.
* score: SMP initialization and shutdown changesSebastian Huber2014-03-061-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | Rename _SMP_Request_other_cores_to_perform_first_context_switch() into _SMP_Request_start_multitasking() since this requests now a multitasking start on all configured and available processors. The name corresponds _Thread_Start_multitasking() and _SMP_Start_multitasking_on_secondary_processor() actions issued in response to this request. Move in source file to right place. Rename PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING into PER_CPU_STATE_READY_TO_START_MULTITASKING. Rename PER_CPU_STATE_BEGIN_MULTITASKING into PER_CPU_STATE_REQUEST_START_MULTITASKING. Rename _SMP_Request_other_cores_to_shutdown() into _SMP_Request_shutdown(). Add a per-CPU state lock to protect all changes. This was necessary to offer a controlled shutdown of the system (atomic read/writes alone are not sufficient for this kind of synchronization). Add documentation for Per_CPU_State. Delete debug output. New tests smptests/smpfatal01 and smptests/smpfatal02.
* score: Rename _Internal_error_Occurred()Sebastian Huber2014-02-211-1/+1
| | | | Rename _Internal_error_Occurred() into _Terminate().
* score: Add and use <rtems/score/smpimpl.h>Sebastian Huber2014-02-191-1/+1
| | | | | Collect SMP implementation specific parts in the <rtems/score/smpimpl.h> header file.
* score: Move _SMP_Request_other_cores_to_shutdown()Sebastian Huber2014-02-191-0/+3
| | | | | | Move _SMP_Request_other_cores_to_shutdown() invocation from rtems_shutdown_executive() to _Internal_error_Occurred() to allow a proper shutdown on SMP configurations even in the error case.
* score: Disable ISR in _Internal_error_Occurred()Sebastian Huber2014-02-191-0/+6
| | | | | | | Disable interrupts as the first step in _Internal_error_Occurred() to get a defined execution context for the fatal extensions. Make _ISR_Disable_without_giant() available for non-SMP configurations.
* score: Add SYSTEM_STATE_TERMINATEDSebastian Huber2014-02-191-1/+1
| | | | | | Merge systems states SYSTEM_STATE_SHUTDOWN and SYSTEM_STATE_FAILED into new system state SYSTEM_STATE_TERMINATED. This reflects that all system termination paths end up in _Internal_error_Occurred().
* Score misc: Clean up Doxygen #4 (GCI 2012)Alexandre Devienne2012-11-281-24/+7
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7985215
* score: Add and use <rtems/score/userextimpl.h>Sebastian Huber2012-11-221-2/+1
| | | | | This file contains the parts of <rtems/score/userext.h> that are only necessary for the RTEMS implementation.
* score: Change _Internal_error_Occurred()Sebastian Huber2012-11-221-2/+1
| | | | | | | Call the fatal handlers of the user extensions before the update of _Internal_errors_What_happened. This reduces the requirements on the execution context further. Now a valid read-write data is only required after the call to the fatal handlers.
* score: Delete nest level from internal error stateSebastian Huber2012-11-221-2/+0
| | | | This reverts commit 7d0bdcac1ac20d6f22b24689c16e6aa7bc3c1e40.
* score: Add nest level to interal error stateSebastian Huber2012-11-151-0/+2
| | | | | Add Internal_errors_Information::nest_level. This helps to detect recursive calls to _Internal_error_Occurred().
* score: Move global variables definitionSebastian Huber2012-11-131-0/+4
| | | | | Define _System_state_Current and _Internal_errors_What_happened in interr.c to make _Internal_error_Occurred() more independent.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* Reflect having introduced Internal_errors_t.Ralf Corsepius2009-10-121-1/+1
* Eliminate TRUE/FALSE.Ralf Corsepius2008-12-221-1/+1
* Convert to "bool".Ralf Corsepius2008-09-041-1/+1
* 2008-07-29 Chris Johns <chrisj@rtems.org>Chris Johns2008-07-291-0/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libblock/Makefile.am: Removed src/show_bdbuf.c. * libblock/src/show_bdbuf.c: Removed. * libblock/include/rtems/bdbuf.h, cpukit/libblock/src/bdbuf.c: Rewritten the bdbuf code. Remove pre-emption disable, score access, fixed many bugs and increased performance. * libblock/include/rtems/blkdev.h: Added RTEMS_BLKDEV_CAPABILITIES block device request. Cleaned up comments. Added block and user fields to the sg buffer request. Move to rtems_* namespace. * libblock/include/rtems/diskdevs.h, cpukit/libblock/src/diskdevs.c: Move to rtems_* namespace. Add a capabilities field for drivers. Change rtems_disk_lookup to rtems_disk_obtain to match the release call. You do not lookup and release a disk, you obtain and release a disk. * libblock/include/rtems/ide_part_table.h, libblock/include/rtems/ramdisk.h, libblock/src/ide_part_table.c: Move to rtems_* namespace. * libblock/include/rtems/nvdisk.h: Formatting change. * libblock/src/blkdev.c: Move to rtems_* namespace. Change rtems_disk_lookup to rtems_disk_obtain * libblock/src/flashdisk.c: Move to rtems_* namespace. Use the new support for the block number in the scatter/grather request struct. This allows non-continuous buffer requests for those drivers that can support increasing performance. * libblock/src/nvdisk.c: Move to rtems_* namespace. Removed warnings. Added better error checking. Fixed some comments. * libblock/src/ramdisk.c: Move to rtems_* namespace. Added some trace functions to help debugging upper layers. Use the new support for the block number in the scatter/grather request struct. This allows non-continuous buffer requests for those drivers that can support increasing performance. * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Use new chains API. Removed temporary hack and changed set_errno_and_return_minus_one to rtems_set_errno_and_return_minus_one. Move fat_buf_access from header and stopped it being inlined. Updated to libblock changes. * libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c, libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Use new chains API. Removed temporary hack and changed set_errno_and_return_minus_one to rtems_set_errno_and_return_minus_one. Updated to libblock changes. * libmisc/Makefile.am: Add new ls and rm command files. * libmisc/shell/cmp-ls.c, libmisc/shell/extern-ls.h, libmisc/shell/filemode.c, libmisc/shell/print-ls.c, libmisc/shell/pwcache.c, libmisc/shell/utils-ls.c, libmisc/shell/vis.c, shell/vis.h: New. * libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c, libmisc/shell/utils-cp.c: Fixed the usage call bug. * libmisc/shell/main_blksync.c: Updated to the new block IO ioctl command. * libmisc/shell/main_ls.c, libmisc/shell/main_rm.c: Updated to BSD commands with more features. * score/src/coremutex.c: Fix the strick order mutex code. * libmisc/shell/shell.c: Change shell tasks mode to be timeslice and no ASR. * sapi/include/confdefs.h: Change ata_driver_task_priority to rtems_ata_driver_task_priority. Add the new BD buf cache parameters with defaults. * score/src/interr.c: Do not return if the CPU halt call returns.
* 2008-06-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-06-021-3/+3
| | | | | * score/include/rtems/score/interr.h, score/src/interr.c: Convention calls for leading underscore on private RTEMS variables.
* Include config.h.Ralf Corsepius2005-01-271-0/+4
* 2005-01-23 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-231-1/+1
| | | | | * sapi/src/fatal.c, score/src/interr.c: Remove volatile on return type.
* 2004-04-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-291-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c, score/src/coretodtickle.c, score/src/coretodtoseconds.c, score/src/coretodvalidate.c, score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapsizeofuserarea.c, score/src/interr.c, score/src/iterateoverthreads.c, score/src/mpci.c, score/src/object.c, score/src/objectallocate.c, score/src/objectallocatebyindex.c, score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetbyindex.c, score/src/objectgetisr.c, score/src/objectgetnoprotection.c, score/src/objectidtoname.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectshrinkinformation.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadget.c, score/src/threadidlebody.c, score/src/threadinitialize.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueuepriority.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadreset.c, score/src/threadrestart.c, score/src/threadsettransient.c, score/src/threadstackallocate.c, score/src/threadstart.c, score/src/userext.c, score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using c99 fixed size types.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/debug.h, include/rtems/seterr.h, include/rtems/system.h, include/rtems/score/address.h, include/rtems/score/apiext.h, include/rtems/score/apimutex.h, include/rtems/score/bitfield.h, include/rtems/score/chain.h, include/rtems/score/context.h, include/rtems/score/copyrt.h, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/heap.h, include/rtems/score/interr.h, include/rtems/score/isr.h, include/rtems/score/mpci.h, include/rtems/score/mppkt.h, include/rtems/score/object.h, include/rtems/score/objectmp.h, include/rtems/score/priority.h, include/rtems/score/stack.h, include/rtems/score/states.h, include/rtems/score/sysstate.h, include/rtems/score/thread.h, include/rtems/score/threadmp.h, include/rtems/score/threadq.h, include/rtems/score/tod.h, include/rtems/score/tqdata.h, include/rtems/score/userext.h, include/rtems/score/watchdog.h, include/rtems/score/wkspace.h, inline/rtems/score/address.inl, inline/rtems/score/chain.inl, inline/rtems/score/coremsg.inl, inline/rtems/score/coremutex.inl, inline/rtems/score/coresem.inl, inline/rtems/score/heap.inl, inline/rtems/score/isr.inl, inline/rtems/score/mppkt.inl, inline/rtems/score/object.inl, inline/rtems/score/objectmp.inl, inline/rtems/score/priority.inl, inline/rtems/score/stack.inl, inline/rtems/score/states.inl, inline/rtems/score/sysstate.inl, inline/rtems/score/thread.inl, inline/rtems/score/threadmp.inl, inline/rtems/score/tod.inl, inline/rtems/score/tqdata.inl, inline/rtems/score/userext.inl, inline/rtems/score/watchdog.inl, inline/rtems/score/wkspace.inl, macros/rtems/score/address.inl, macros/rtems/score/chain.inl, macros/rtems/score/coremsg.inl, macros/rtems/score/coremutex.inl, macros/rtems/score/coresem.inl, macros/rtems/score/heap.inl, macros/rtems/score/isr.inl, macros/rtems/score/mppkt.inl, macros/rtems/score/object.inl, macros/rtems/score/objectmp.inl, macros/rtems/score/priority.inl, macros/rtems/score/stack.inl, macros/rtems/score/states.inl, macros/rtems/score/sysstate.inl, macros/rtems/score/thread.inl, macros/rtems/score/threadmp.inl, macros/rtems/score/tod.inl, macros/rtems/score/tqdata.inl, macros/rtems/score/userext.inl, macros/rtems/score/watchdog.inl, macros/rtems/score/wkspace.inl, src/apiext.c, src/chain.c, src/coremsg.c, src/coremsgbroadcast.c, src/coremsgclose.c, src/coremsgflush.c, src/coremsgflushsupp.c, src/coremsgflushwait.c, src/coremsginsert.c, src/coremsgseize.c, src/coremsgsubmit.c, src/coremutex.c, src/coremutexflush.c, src/coremutexseize.c, src/coremutexsurrender.c, src/coresem.c, src/coresemflush.c, src/coresemseize.c, src/coresemsurrender.c, src/coretod.c, src/coretodset.c, src/coretodtickle.c, src/coretodtoseconds.c, src/coretodvalidate.c, src/heap.c, src/heapallocate.c, src/heapextend.c, src/heapfree.c, src/heapgetinfo.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/interr.c, src/isr.c, src/iterateoverthreads.c, src/mpci.c, src/object.c, src/objectallocate.c, src/objectallocatebyindex.c, src/objectclearname.c, src/objectcomparenameraw.c, src/objectcomparenamestring.c, src/objectcopynameraw.c, src/objectcopynamestring.c, src/objectextendinformation.c, src/objectfree.c, src/objectget.c, src/objectgetbyindex.c, src/objectgetisr.c, src/objectgetnext.c, src/objectgetnoprotection.c, src/objectidtoname.c, src/objectinitializeinformation.c, src/objectmp.c, src/objectnametoid.c, src/objectshrinkinformation.c, src/thread.c, src/threadchangepriority.c, src/threadclearstate.c, src/threadclose.c, src/threadcreateidle.c, src/threaddelayended.c, src/threaddispatch.c, src/threadevaluatemode.c, src/threadget.c, src/threadhandler.c, src/threadidlebody.c, src/threadinitialize.c, src/threadloadenv.c, src/threadmp.c, src/threadq.c, src/threadqdequeue.c, src/threadqdequeuefifo.c, src/threadqdequeuepriority.c, src/threadqenqueue.c, src/threadqenqueuefifo.c, src/threadqenqueuepriority.c, src/threadqextract.c, src/threadqextractfifo.c, src/threadqextractpriority.c, src/threadqextractwithproxy.c, src/threadqfirst.c, src/threadqfirstfifo.c, src/threadqfirstpriority.c, src/threadqflush.c, src/threadqtimeout.c, src/threadready.c, src/threadreset.c, src/threadresettimeslice.c, src/threadrestart.c, src/threadresume.c, src/threadrotatequeue.c, src/threadsetpriority.c, src/threadsetstate.c, src/threadsettransient.c, src/threadstackallocate.c, src/threadstackfree.c, src/threadstart.c, src/threadstartmultitasking.c, src/threadsuspend.c, src/threadtickletimeslice.c, src/threadyieldprocessor.c, src/userext.c, src/watchdog.c, src/watchdogadjust.c, src/watchdoginsert.c, src/watchdogremove.c, src/watchdogtickle.c, src/wkspace.c: URL for license changed.
* posix support initially addedJoel Sherrill1995-09-261-3/+3
* moving files aroundJoel Sherrill1995-09-211-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-0/+61
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API.
