* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | score: Limit the CLOCK_REALTIME setting | Sebastian Huber | 2021-09-06 | 1 | -1/+1 |
| | | | | | Limit the CLOCK_REALTIME setting to ensure that the CLOCK_REALTIME is defined for a system uptime of at least 114 years. | ||||
* | score: Add _TOD_Is_valid_new_time_of_day() | Sebastian Huber | 2021-09-06 | 1 | -0/+59 |
Move the TOD validation to the callers of _TOD_Set(). This avoids dead code in case only rtems_clock_set() is used in an application because rtems_clock_set() always calls _TOD_Set() with a valid time of day. |
