line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3243.
Update #3117.
Update #3182.
Replace _Thread_Timer_insert_monotonic() with
_Thread_Add_timeout_ticks().
Update #3117.
Update #3182.
Rename _Watchdog_Per_CPU_insert_monotonic() in
_Watchdog_Per_CPU_insert_ticks().
Update #3117.
Update #3182.
Rename PER_CPU_WATCHDOG_RELATIVE in PER_CPU_WATCHDOG_MONOTONIC to
highlight the corresponding POSIX CLOCK_MONOTONIC.
Rename PER_CPU_WATCHDOG_ABSOLUTE in PER_CPU_WATCHDOG_REALTIME to
highlight the corresponding POSIX CLOCK_REALTIME.
Update #3117.
Update #3182.
Rename struct Scheduler_Control to _Scheduler_Control to allow its use
in standard header files, e.g. <pthread.h>.
Update #3112.
Move _Thread_Scheduler_ask_for_help(), rename it to
_Thread_Ask_for_help() and make it static.
Add configuration option CONFIGURE_MAXIMUM_THREAD_NAME_SIZE.
Update #2858.
Update #2858.
Initialize thread queue context early preferably outside the critical
section.
Remove implicit _Thread_queue_Context_initialize() from
_Thread_Wait_acquire().
Replace the expected thread dispatch disable level with a thread queue
enqueue callout. This enables the use of _Thread_Dispatch_direct() in
the thread queue enqueue procedure. This avoids impossible exection
paths, e.g. Per_CPU_Control::dispatch_necessary is always true.
Maintain the thread resource count only in debug configurations. This
is a performance optimization for non-debug configurations.
This makes it easier to conditionally enable/disable the thread resource
count usage.
Replace Thread_Scheduler_control::control and
Thread_Scheduler_control::own_control with new
Thread_Scheduler_control::home.
Update #2556.
Update #2556.
Update #2556.
Delete Thread_Control::Resource_node.
Update #2556.
Update #2556.
Update #2556.
Update #2556.
Add the ability to add/remove scheduler nodes to/from the set of
scheduler nodes available to the schedulers for a particular thread.
Update #2556.
Update #2556.
Update #2556.
Update #2556.
Update #2423.
Maintain the priority of a thread for each scheduler instance via the
thread queue enqueue, extract, priority actions and surrender
operations. This replaces the primitive priority boosting.
Update #2556.
Update #2556.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Avoid direct access to thread internal data fields.
Update #2556.
Update #2556.
Introduce Thread_queue_Lock_context to contain the context necessary for
thread queue lock and thread wait lock acquire/release operations to
reduce the Thread_Control size.
This information turned out to be useless in the last couple of months.
There was a subtile race condition in _Thread_queue_Do_extract_locked().
It must first update the thread wait flags and then restore the default
thread wait state. In the previous implementation this could lead under
rare timing conditions to an ineffective _Thread_Wait_tranquilize()
resulting to a corrupt system state.
Update #2556.
The _Thread_Lock_acquire() function had a potentially infinite run-time
due to the lack of fairness at atomic operations level.
Update #2412.
Update #2556.
Update #2765.
Move the priority change due to priority interitance to the thread queue
enqueue operation to simplify the locking on SMP configurations.
Update #2412.
Update #2556.
Update #2765.
Update #2412.
Update #2556.
Update #2765.
Clock disciplines may be WATCHDOG_RELATIVE, WATCHDOG_ABSOLUTE,
or WATCHDOG_NO_TIMEOUT. A discipline of WATCHDOG_RELATIVE with
a timeout of WATCHDOG_NO_TIMEOUT is equivalent to a discipline
of WATCHDOG_NO_TIMEOUT.
updates #2732
The use of atomic fences is brittle and may break due to changes in
different areas which is hard to manage.
According to the C11 standard only atomic read-modify-write operations
guarantee that the last value written in modification order is read, see
"7.17.3 Order and consistency". Thus we must use a read-modify-write in
_SMP_Inter_processor_interrupt_handler() to make sure we read an
up-to-date message.
The thread priority is manifest in two independent areas. One area is
the user visible thread priority along with a potential thread queue.
The other is the scheduler. Currently, a thread priority update via
_Thread_Change_priority() first updates the user visble thread priority
and the thread queue, then the scheduler is notified if necessary. The
priority is passed to the scheduler via a local variable. A generation
counter ensures that the scheduler discards out-of-date priorities.
This use of a local variable ties the update in these two areas close
together. For later enhancements and the OMIP locking protocol
implementation we need more flexibility. Add a thread priority
information block to Scheduler_Node and synchronize priority value
updates via a sequence lock on SMP configurations.
Update #2556.
The approach with the generation number was broken. The load/store of
the current lock, the thread queue and the thread queue operations were not
properly synchronized. Under certain conditions on a PowerPC T4240 old
thread queue operations operated on a new thread queue (NULL pointer).
A read-modify-write operation is necessary to read the last value
written.
See for example C11 standard or Power ISA 2.07, Book II: Power ISA
Virtual Environment Architecture, Section 1.6.3 Memory Coherence
Required [Category: Memory Coherence] and Section 1.7.3 Atomic Update.
Move the safety check performed by
_CORE_mutex_Check_dispatch_for_seize() out of the performance critical
path and generalize it. Blocking on a thread queue with an unexpected
thread dispatch disabled level is illegal in all system states.
Add the expected thread dispatch disable level (which may be 1 or 2
depending on the operation) to Thread_queue_Context and use it in
_Thread_queue_Enqueue_critical().
