* | Do not use RTEMS_INLINE_ROUTINE | Sebastian Huber | 2022-09-19 | 1 | -10/+10 |
| | | | | | | | Directly use "static inline" which is available in C99 and later. This brings the RTEMS implementation closer to standard C. Close #3935. | ||||
* | bsps/x86_64: Add APIC timer based clock driver | Amaan Cheval | 2018-08-13 | 1 | -0/+23 |
| | | | | | | | | | The APIC timer is calibrated by running the i8254 PIT for a fraction of a second (determined by PIT_CALIBRATE_DIVIDER) and counting how many times the APIC counter has ticked. The calibration can be run multiple times (determined by APIC_TIMER_NUM_CALIBRATIONS) and averaged out. Updates #2898. | ||||
* | bsps/x86_64: Add support for RTEMS interrupts | Amaan Cheval | 2018-08-13 | 1 | -0/+18 |
* | bsps/x86_64: Add paging support with 1GiB super pages | Amaan Cheval | 2018-08-13 | 1 | -0/+13 |
* | bsps/x86_64: Reorganize header files and compile-options | Amaan Cheval | 2018-08-13 | 1 | -0/+50 |
Updates #2898. |
