path: root/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h (follow)
* score: Add _CPU_Get_TLS_thread_pointer()Sebastian Huber2023-09-151-0/+8
| | | | | | | | Add _CPU_Get_TLS_thread_pointer() to get the thread pointer which is used to get the address of thread-local storage objects associated with a thread. Update #4920.
* v850/include/rtems/score/cpuimpl.h: Address unused parameter warningJoel Sherrill2023-08-211-0/+4
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* score: Add CPU_THREAD_LOCAL_STORAGE_VARIANTSebastian Huber2022-10-141-0/+2
| | | | Update #3835.
* Do not use RTEMS_INLINE_ROUTINESebastian Huber2022-09-191-5/+5
| | | | | | | Directly use "static inline" which is available in C99 and later. This brings the RTEMS implementation closer to standard C. Close #3935.
* score: Add _CPU_Use_thread_local_storage()Sebastian Huber2022-07-041-0/+7
| | | | | | | | | | | | At some point during system initialization, the idle threads are created. Afterwards, the boot processor basically executes within the context of an idle thread with thread dispatching disabled. On some architectures, the thread-local storage area of the associated thread must be set in dedicated processor registers. Add the new CPU port function to do this: void _CPU_Use_thread_local_storage( const Context_Control *context ) Close #4672.
* score/cpu/v850: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Canonicalize _CPU_Fatal_halt()Sebastian Huber2021-07-281-0/+2
| | | | | | | | Move _CPU_Fatal_halt() declaration to <rtems/score/cpuimpl.h> and make sure it is a proper declaration of a function which does not return. Fix the type of the error code. If necessary, add the implementation to cpu.c. Implementing _CPU_Fatal_halt() as a function makes it possible to wrap this function for example to fully test _Terminate().
* doxygen: score: Add V850 CPU architecture groupAndreas Dachsberger2019-04-021-0/+12
| | | | Update #3706.
* score: Add _CPU_Instruction_illegal()Sebastian Huber2018-07-231-0/+5
| | | | | | | | On some architectures/simulators it is difficult to provoke an exception with misaligned or illegal data loads. Use an illegal instruction instead. Update #3433.
* score: Add _CPU_Instruction_no_operation()Sebastian Huber2018-07-201-0/+5
| | | | | This helps to reduce the use of architecture-specific defines throughout the code base.
* score: Move context validation declarationsSebastian Huber2018-07-201-0/+12
| | | | | | | The context validation support functions _CPU_Context_validate() and _CPU_Context_volatile_clobber() are used only by one test program (spcontext01). Move the function declarations to the CPU port implementation header file.
* Remove make preinstallChris Johns2018-01-251-0/+34
