* | powerpc: Remove use of proc_ptr | Sebastian Huber | 2018-11-12 | 1 | -35/+0 |
| | | | | Update #3585. | ||||
* | score: Introduce _Internal_error() | Sebastian Huber | 2016-12-12 | 1 | -1/+1 |
* | score: Remove fatal is internal indicator | Sebastian Huber | 2016-12-09 | 1 | -5/+1 |
| | | | | | | | | | The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825. | ||||
* | score: Rename _Internal_error_Occurred() | Sebastian Huber | 2014-02-21 | 1 | -1/+1 |
| | | | | Rename _Internal_error_Occurred() into _Terminate(). | ||||
* | score misc: Clean up Doxygen GCI Task #12 | Alex Ivanov | 2012-12-07 | 1 | -0/+6 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7983217 | ||||
* | score: Add INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR | Sebastian Huber | 2012-11-15 | 1 | -0/+33 |
Use INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR on PowerPC for _CPU_ISR_install_vector(). |
