path: root/cpukit/score/cpu/powerpc/headers.am (follow)
* build: Remove old build systemSebastian Huber2021-09-211-9/+0
| | | | | Close #3250. Close #4081.
* build: Include header.am in cpukit/Makefile.amSebastian Huber2018-10-101-20/+8
| | | | | Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets rid of all subtree Makefile.am and the sudirs hack.
* Add PowerPC paravirtualization supportJoel Sherrill2018-03-131-0/+1
| | | | | | | | | Cannot read or write MSR when executing in user mode. This is used when RTEMS_PARAVIRT is defined. Provide alternate methods to disable/enable interrupts Closes #3306.
* powerpc/include/rtems/score/types.h: Eliminate this fileJoel Sherrill2018-03-121-1/+0
| | | | Updates #3327.
* Remove make preinstallChris Johns2018-01-251-0/+21
