* | Remove (Obsolete). | Ralf Corsepius | 2005-04-23 | 11 | -2525/+0 |
* | 2005-04-23 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-23 | 1 | -0/+7 |
| | | | | | | | * rtems/score/types.h, rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/or32.h, rtems/asm.h, Makefile.am, cpu.c, cpu_asm.c, preinstall.am: Remove. | ||||
* | Auto-generated update. | Ralf Corsepius | 2005-02-19 | 1 | -1/+1 |
* | Cosmetics. | Ralf Corsepius | 2005-02-19 | 1 | -1/+1 |
* | 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-08 | 3 | -35/+52 |
| | | | | | * Makefile.am: Split out preinstallation rules. * preinstall.am: New (Split out from Makefile.am). | ||||
* | Header guards cleanup. | Ralf Corsepius | 2005-02-04 | 1 | -1/+1 |
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 3 | -102/+9 |
| | | | | | | | PR 754/rtems * rtems/asm.h: New (relocated from .). * asm.h: Remove (moved to rtems/asm.h). * Makefile.am: Reflect changes above. | ||||
* | New header guard. | Ralf Corsepius | 2005-01-28 | 6 | -12/+12 |
* | 2004-01-28 Ralf Corsepius <ralf.corsepiu@rtems.org> | Ralf Corsepius | 2005-01-28 | 1 | -0/+5 |
| | | | | | * asm.h, rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/or32.h, rtems/score/types.h: New header guards. | ||||
* | 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-24 | 2 | -6/+5 |
| | | | | | * rtems/score/types.h: Remove signed8, signed16, signed32, unsigned8, unsigned16, unsigned32. | ||||
* | 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-24 | 2 | -2/+6 |
| | | | | * rtems/score/cpu.h: *_swap_u32( uint32_t ). | ||||
* | 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-24 | 2 | -0/+6 |
| | | | | * rtems/score/types.h: #include <rtems/stdint.h>. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@freenet.de> | Ralf Corsepius | 2005-01-07 | 2 | -1/+5 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-01 | 2 | -9/+7 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | Cosmetics. | Ralf Corsepius | 2004-11-21 | 4 | -4/+0 |
* | 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-11-21 | 2 | -2/+7 |
| | | | | | * rtems/score/types.h: Use __rtems_score_types_h as preprocessor guard. | ||||
* | 2004-11-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-11-21 | 3 | -6/+14 |
| | | | | * asm.h: Add doxygen preamble. | ||||
* | 2004-10-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-02 | 5 | -8/+26 |
| | | | | | | | * rtems/score/cpu.h: Add doxygen preamble. * rtems/score/cpu_asm.h: Add doxygen preamble. * rtems/score/or32.h: Add doxygen preamble. * rtems/score/types.h: Add doxygen preamble. | ||||
* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 2 | -5/+5 |
| | | | | * rtems/score/cpu.h: i960 obsoleted and all references removed. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 3 | -5/+0 |
* | Cleanup | Ralf Corsepius | 2004-04-06 | 1 | -12/+0 |
* | 2004-04-06 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-06 | 3 | -31/+8 |
| | | | | | | * configure.ac: Remove (Merged into$(top_srcdir)/configure.ac). * Makefile.am: Don't include multilib.am. Reflect merging configure.ac into $(top_srcdir)/configure.ac. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -8/+13 |
| | | | | * Makefile.am: Install asm.h to $(includedir)/rtems. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-30 | 4 | -36/+41 |
| | | | | | * cpu.c, cpu_asm.c, rtems/score/cpu.h: Convert to using c99 fixed size types. | ||||
* | 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-29 | 2 | -1/+5 |
| | | | | * configure.ac: RTEMS_TOP([../../../..]). | ||||
* | Unused. | Ralf Corsepius | 2004-03-08 | 2 | -4/+0 |
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -1/+5 |
| | | | | * configure.ac: Move RTEMS_TOP one subdir down. | ||||
* | 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-19 | 2 | -2/+8 |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+9 |
| | | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. | ||||
* | 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-12 | 2 | -1/+5 |
| | | | | * configure.ac: Requires automake >= 1.8.1. | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -1/+5 |
| | | | | * Makefile.am: Include compile.am, again. | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -11/+14 |
| | | | | * Makefile.am: Convert to using automake compilation rules. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -4/+6 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -12/+18 |
| | | | | * Makefile.am:Restore further parts having been lost. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -2/+53 |
| | | | | * Makefile.am: Restore file having been broken in last commit. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 2 | -60/+6 |
| | | | | * Makefile.am: Remove TMPINSTALL_FILES. | ||||
* | 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-30 | 2 | -12/+22 |
| | | | | * Makefile.am: Add $(dirstamp) to preinstallation rules. | ||||
* | 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-23 | 2 | -20/+32 |
| | | | | * Makefile.am: Don't use gmake rules for preinstallation. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CPU. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 2 | -7/+5 |
| | | | | | * rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all references. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 7 | -6/+11 |
| | | | | | * cpu.c, cpu_asm.c, rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/or32.h, rtems/score/types.h: URL for license changed. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-11 | 3 | -6/+9 |
| | | | | | * configure.ac: Require autoconf-2.57 + automake-1.7.2. * Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS. | ||||
* | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-19 | 2 | -1/+5 |
| | | | | * configure.ac: Fix package name. | ||||
* | 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-25 | 2 | -1/+5 |
| | | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-09-14 Ivan Guzvinec <ivang@opencores.org> | Joel Sherrill | 2002-09-14 | 2 | -0/+16 |
| | | | | | * rtems/score/cpu.h (_CPU_Initialize_vectors) Define to NULL since it is not used. |
