path: root/cpukit/score/cpu/or1k/include/rtems/score/or1k-utility.h (follow)
* Use __asm__ for standard C compatibilitySebastian Huber2022-07-271-5/+5
* score/cpu/or1k: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
* Remove make preinstallChris Johns2018-01-251-0/+396
