* .cvsignore, ChangeLog, asm.h, configure.ac, cpu.c, cpu_asm.c,
rtems/score/.cvsignore, rtems/score/cpu.h, rtems/score/cpu_asm.h,
rtems/score/or16.h, rtems/score/types.h: Removed as the or16 port
was just a stub and only the OR32 port is getting worked on.
* Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems.c: Remove.
* configure.ac: Add RTEMS_PROG_CCAS
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..).
Add AC_PROG_RANLIB.
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am.
Use ../../../aclocal.
* rtems/score/or16types.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* rtems/Makefile.am: Removed.
* Makefile.am: Add multilib support.
This was tracked as PR91.
* configure.in: Remove.
* Shell added for or16 port based on no_cpu port with names replaced.
