path: root/cpukit/score/cpu/no_cpu/rtems (follow)
* Remove make preinstallChris Johns2018-01-256-1900/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* score: Add optional _CPU_Context_Destroy()Sebastian Huber2017-07-251-0/+19
| | | | Update #3077.
* score: Delete _CPU_Context_Fp_start()Sebastian Huber2017-01-261-26/+0
| | | | | | | | | | Since the FP area pointer is passed by reference in _CPU_Context_Initialize_fp() the optional FP area adjustment via _CPU_Context_Fp_start() is superfluous. It is also wrong with respect to memory management, e.g. pointer passed to _Workspace_Free() may be not the one returned by _Workspace_Allocate(). Close #1400.
* Remove CPU_BIG_ENDIAN and CPU_LITTLE_ENDIANSebastian Huber2017-01-241-40/+0
| | | | | | Use de-facto standard BYTE_ORDER instead. Close #2803.
* score: Fix ARM and PowerPC context initializationSebastian Huber2016-12-021-0/+4
| | | | Update #2751.
* score: Robust thread dispatchSebastian Huber2016-11-231-0/+12
| | | | | | | | | | | | On SMP configurations, it is a fatal error to call blocking operating system with interrupts disabled, since this prevents delivery of inter-processor interrupts. This could lead to executing threads which are not allowed to execute resulting in undefined behaviour. The ARM Cortex-M port has a similar problem, since the interrupt state is not a part of the thread context. Update #2811.
* score: Add _ISR_Is_enabled()Sebastian Huber2016-11-181-0/+14
| | | | | | | In contrast to _ISR_Get_level() the _ISR_Is_enabled() function evaluates a level parameter and returns a boolean value. Update #2811.
* rtems: Conditionally define rtems_interrupt_frameSebastian Huber2016-11-181-1/+1
| | | | Update #2808.
* score: Move CPU_PER_CPU_CONTROL_SIZESebastian Huber2016-11-182-23/+23
| | | | | Move CPU_PER_CPU_CONTROL_SIZE and the optional CPU_Per_CPU_control to <rtems/score/cpuimpl.h> to hide it from <rtems.h>.
* score: Remove obsolete definesSebastian Huber2016-11-181-23/+0
| | | | The thread dispatch inline option is no longer used.
* score: Move _CPU_Get_current_per_CPU_control()Sebastian Huber2016-11-102-19/+19
| | | | | Move _CPU_Get_current_per_CPU_control() from <rtems/score/cpu.h> to <rtems/score/cpuimpl.h>.
* score: Add optional _CPU_Get_thread_executing()Sebastian Huber2016-11-071-0/+12
* score: Add <rtems/score/cpuimpl.h>Sebastian Huber2016-11-071-0/+30
| | | | | | The aim of this file is to encapsulate CPU port implementation details. This helps to hide implementation details from <rtems.h> which indirectly includes <rtems/score/cpu.h>.
* score: Fix C/C++ compatibility issueSebastian Huber2016-09-231-1/+5
| | | | | | | Only use CPU_Per_CPU_control if it contains at least one filed. In GNU C empty structures have a size of zero. In C++ structures have a non-zero size. In case CPU_PER_CPU_CONTROL_SIZE is defined to zero, then this structure is not used anymore.
* score: _CPU_SMP_Send_interrupt() documentationSebastian Huber2016-06-291-4/+0
* score: Simplify priority bit map implementationSebastian Huber2016-06-081-3/+0
| | | | | | | | | | The priority bit map can deal with a maximum of 256 priority values ranging from 0 to 255. Consistently use an unsigned int for computation, due to the usual integer promotion rules. Make Priority_bit_map_Word definition architecture-independent and define it to uint16_t. This was already the case for all architectures except PowerPC. Adjust the PowerPC bitmap support accordingly.
* score: Delete CPU_USE_GENERIC_BITFIELD_DATASebastian Huber2016-06-081-10/+0
| | | | | | Rename __log2table into _Bitfield_Leading_zeros since it acually returns the count of leading zeros of an 8-bit integer. The value for zero is a bit odd. Provide it unconditionally.
* score: Add CPU_MAXIMUM_PROCESSORSSebastian Huber2016-03-041-0/+6
| | | | Maximum number of processors of all systems supported by this CPU port.
* no_cpu: Avoid SCORE_EXTERNSebastian Huber2016-02-171-1/+1
| | | | Update #2559.
* score: Introduce CPU_CACHE_LINE_BYTESSebastian Huber2016-01-261-13/+8
| | | | | Add CPU_CACHE_LINE_BYTES for the maximum cache line size in bytes. The actual processor may use no cache or a smaller cache line size.
* score: Delete obsolete CPU_TIMESTAMP_* definesSebastian Huber2016-01-251-68/+0
| | | | Update #2271.
* basedefs.h: Add and use RTEMS_NO_RETURNSebastian Huber2015-10-261-1/+1
* SMP: Fix and optimize thread dispatchingSebastian Huber2015-09-281-14/+25
| | | | | | | | According to the C11 and C++11 memory models only a read-modify-write operation guarantees that we read the last value written in modification order. Avoid the sequential consistent thread fence and instead use the inter-processor interrupt to set the thread dispatch necessary indicator.
* cpukit: add and use CPU_Uint32ptr typeGedare Bloom2015-03-161-0/+3
* score: Delete unused CPU_UNROLL_ENQUEUE_PRIORITYSebastian Huber2015-03-051-23/+0
* score: Add _CPU_SMP_Prepare_start_multitasking()Sebastian Huber2015-02-171-0/+12
| | | | Update #2268.
* Let CPU/BSP Fatal handler have access to sourceDaniel Hellstrom2014-09-101-1/+1
| | | | | | | | | Without the source the error code does not say that much. Let it be up to the CPU/BSP to determine the error code reported on fatal shutdown. This patch does not change the current behaviour, just adds the option to handle the source of the fatal halt.
* score: PR2183: Fix context switch on SMPSebastian Huber2014-07-041-2/+31
| | | | | | | | Fix context switch on SMP for ARM, PowerPC and SPARC. Atomically test and set the is executing indicator of the heir context to ensure that at most one processor uses the heir context. Break the busy wait loop also due to heir updates.
* score: Fix CPU context usage on SMPSebastian Huber2014-05-081-3/+23
| | | | | | | | | | We must not alter the is executing indicator in _CPU_Context_Initialize() since this would cause an invalid state during a self restart. The is executing indicator must be valid at creation time since otherwise _Thread_Kill_zombies() uses an undefined value for not started threads. This could result in a system life lock.
* score: Implement forced thread migrationSebastian Huber2014-05-071-0/+18
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | The current implementation of task migration in RTEMS has some implications with respect to the interrupt latency. It is crucial to preserve the system invariant that a task can execute on at most one processor in the system at a time. This is accomplished with a boolean indicator in the task context. The processor architecture specific low-level task context switch code will mark that a task context is no longer executing and waits that the heir context stopped execution before it restores the heir context and resumes execution of the heir task. So there is one point in time in which a processor is without a task. This is essential to avoid cyclic dependencies in case multiple tasks migrate at once. Otherwise some supervising entity is necessary to prevent life-locks. Such a global supervisor would lead to scalability problems so this approach is not used. Currently the thread dispatch is performed with interrupts disabled. So in case the heir task is currently executing on another processor then this prolongs the time of disabled interrupts since one processor has to wait for another processor to make progress. It is difficult to avoid this issue with the interrupt latency since interrupts normally store the context of the interrupted task on its stack. In case a task is marked as not executing we must not use its task stack to store such an interrupt context. We cannot use the heir stack before it stopped execution on another processor. So if we enable interrupts during this transition we have to provide an alternative task independent stack for this time frame. This issue needs further investigation.
* score: Statically initialize _ISR_Vector_tableSebastian Huber2014-04-291-6/+11
* score: Add _CPU_Get_current_per_CPU_control()Sebastian Huber2014-04-281-0/+18
| | | | | | | | | Add optional method _CPU_Get_current_per_CPU_control() to obtain the per-CPU control of the current processor. This is optional. Not every CPU port needs this. It is only an optional optimization variant. In case this macro is undefined, the default implementation using the current processor index will be used.
* score: SMP initialization changesSebastian Huber2014-04-141-8/+36
| | | | | | | | | | | | | | | | | Add and use _CPU_SMP_Start_processor(). Add and use _CPU_SMP_Finalize_initialization(). This makes most _CPU_SMP_Initialize() functions a bit simpler since we can calculate the minimum value of the count of processors requested by the application configuration and the count of physically or virtually available processors in the high-level code. The CPU port has now the ability to signal a processor start failure. With the support for clustered/partitioned scheduling the presence of particular processors can be configured to be optional or mandatory. There will be a fatal error only in case mandatory processors are not present. The CPU port may use a timeout to monitor the start of a processor.
* score: Clarify CPU port alignment requirementsSebastian Huber2014-04-071-7/+9
* score: Rename Priority_bit_map_ControlSebastian Huber2014-04-032-2/+2
| | | | Rename Priority_bit_map_Control in Priority_bit_map_Word.
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-214-4/+4
* score: SMP initialization and shutdown changesSebastian Huber2014-03-061-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | Rename _SMP_Request_other_cores_to_perform_first_context_switch() into _SMP_Request_start_multitasking() since this requests now a multitasking start on all configured and available processors. The name corresponds _Thread_Start_multitasking() and _SMP_Start_multitasking_on_secondary_processor() actions issued in response to this request. Move in source file to right place. Rename PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING into PER_CPU_STATE_READY_TO_START_MULTITASKING. Rename PER_CPU_STATE_BEGIN_MULTITASKING into PER_CPU_STATE_REQUEST_START_MULTITASKING. Rename _SMP_Request_other_cores_to_shutdown() into _SMP_Request_shutdown(). Add a per-CPU state lock to protect all changes. This was necessary to offer a controlled shutdown of the system (atomic read/writes alone are not sufficient for this kind of synchronization). Add documentation for Per_CPU_State. Delete debug output. New tests smptests/smpfatal01 and smptests/smpfatal02.
* score: _CPU_SMP_Get_current_processor()Sebastian Huber2014-02-211-2/+1
| | | | | | | Remove RTEMS_COMPILER_PURE_ATTRIBUTE from _SMP_Get_current_processor() and all _CPU_SMP_Get_current_processor(). Make inline ASM statements volatile again. Test smptests/smpmigration01 showed that GCC optimizes too much otherwise.
* score: Rename bsp_smp_initialize()Sebastian Huber2014-02-191-0/+18
| | | | | Rename bsp_smp_initialize() into _CPU_SMP_Initialize() since every CPU port must supply this function.
* score: Use atomic API for SMP lockSebastian Huber2014-02-171-118/+0
| | | | | Use a ticket lock implementation based on atomic operations. Delete CPU port specific SMP lock implementations.
* score: Add CPU counter supportSebastian Huber2014-02-141-0/+34
| | | | | | | | | Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter.
* Add thread-local storage (TLS) supportSebastian Huber2014-02-041-1/+2
| | | | | Tested and implemented on ARM, m68k, PowerPC and SPARC. Other architectures need more work.
* no_cpu/cpusmplock.h: Clean up to be compilableJoel Sherrill2013-12-141-0/+4
* no_cpu/.../cpu.h: Comment improvementJoel Sherrill2013-11-141-0/+5
* score/cpu: Add CPU_Per_CPU_controlSebastian Huber2013-08-091-0/+18
| | | | Add CPU port specific per-CPU control.
* smp: Rename _CPU_Processor_event_receive()Sebastian Huber2013-07-171-2/+2
| | | | Rename to _CPU_SMP_Processor_event_receive().
* smp: Rename _CPU_Processor_event_broadcast()Sebastian Huber2013-07-171-2/+2
| | | | Rename to _CPU_SMP_Processor_event_broadcast().
* smp: Add and use _CPU_SMP_Send_interrupt()Sebastian Huber2013-07-171-0/+10
| | | | Delete bsp_smp_interrupt_cpu().
* smp: Add and use _CPU_SMP_Get_current_processor()Sebastian Huber2013-07-171-0/+13
| | | | | | | | | | Add and use _SMP_Get_current_processor() and rtems_smp_get_current_processor(). Delete bsp_smp_interrupt_cpu(). Change type of current processor index from int to uint32_t to match _SMP_Processor_count type.
* documentation: Fix Doxygen commentsSebastian Huber2013-06-141-4/+4
