brains GmbH.
Updates #4625.
Updates #3053.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013205
* nios2-eic-il-low-level.S, nios2-eic-rsie-low-level.S: New files.
* rtems/score/cpu.h, rtems/score/nios2-utility.h,
nios2-thread-dispatch-disabled.c, nios2-context-switch.S: Added
support for thread stack protection via the MPU.
* nios2-thread-dispatch-disabled.c: Use offsetof() instead of
RTEMS_offsetof().
* cpu.c, cpu_asm.S: Removed files.
* nios2-context-initialize.c, nios2-context-switch.S,
nios2-fatal-halt.c, nios2-initialize-vectors.c, nios2-initialize.c,
nios2-isr-get-level.c, nios2-isr-install-raw-handler.c,
nios2-isr-install-vector.c, nios2-isr-is-in-progress.c,
nios2-isr-set-level.c, nios2-thread-dispatch-disabled.c,
rtems/score/nios2-utility.h: New files.
* Makefile.am, preinstall.am: Reflect changes above.
* irq.c: Update due to API changes.
* rtems/score/cpu.h: New functions _CPU_Initialize_vectors(),
_CPU_ISR_Set_level(), and _CPU_Fatal_halt() (instead of macros).
Support for external interrupt controller (EIC). Documentation
changes.
