brains GmbH.
Update #3835.
Updates #3053.
Update #4214.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
Rename _Internal_error_Occurred() into _Terminate().
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
* nios2-mpu-configuration.c, nios2-mpu-descriptor.c,
nios2-mpu-disable-protected.c, nios2-mpu-reset.c: New files.
* rtems/score/nios2-utility.h, nios2-context-initialize.c: Added
support for the memory protection unit (MPU).
* rtems/score/nios2-utility.h: Avoid redefines with Altera HAL.
Declare _Nios2_ISR_Set_level().
* nios2-context-initialize.c: Use _Nios2_ISR_Set_level().
* nios2-isr-set-level.c: Define _Nios2_ISR_Set_level().
* cpu.c, cpu_asm.S: Removed files.
* nios2-context-initialize.c, nios2-context-switch.S,
nios2-fatal-halt.c, nios2-initialize-vectors.c, nios2-initialize.c,
nios2-isr-get-level.c, nios2-isr-install-raw-handler.c,
nios2-isr-install-vector.c, nios2-isr-is-in-progress.c,
nios2-isr-set-level.c, nios2-thread-dispatch-disabled.c,
rtems/score/nios2-utility.h: New files.
* Makefile.am, preinstall.am: Reflect changes above.
* irq.c: Update due to API changes.
* rtems/score/cpu.h: New functions _CPU_Initialize_vectors(),
_CPU_ISR_Set_level(), and _CPU_Fatal_halt() (instead of macros).
Support for external interrupt controller (EIC). Documentation
changes.
