path: root/cpukit/score/cpu/moxie/include/rtems/score/moxie.h (follow)
* cpukit/score/cpu/moxie: Change license to BSD-2Joel Sherrill2022-04-011-3/+22
| | | | | | Permission received from Anthony Green. Updates #3053.
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+43
