line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
The priority bit map can deal with a maximum of 256 priority values
ranging from 0 to 255. Consistently use an unsigned int for
computation, due to the usual integer promotion rules.
Make Priority_bit_map_Word definition architecture-independent and
define it to uint16_t. This was already the case for all architectures
except PowerPC. Adjust the PowerPC bitmap support accordingly.
Rename Priority_bit_map_Control in Priority_bit_map_Word.
PR 1635/cpukit
* rtems/score/types.h: Refactoring of priority handling, to isolate the
bitmap implementation of priorities in the supercore so that priority
management is a little more modular. This change is in anticipation
of scheduler implementations that can select how they manage tracking
priority levels / finding the highest priority ready task. Note that
most of the changes here are simple renaming, to clarify the use of
the bitmap-based priority management.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* rtems/score/types.h: Remove unsigned64, signed64.
* rtems/score/types.h: Eliminate unsigned16, unsigned32.
* rtems/score/types.h: Remove signed8, signed16, signed32,
unsigned8, unsigned16, unsigned32.
* rtems/score/types.h: #include <rtems/stdint.h>.
* rtems/score/types.h: Use __rtems_score_types_h as preprocessor
guard.
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/m68k.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/m68k.h,
rtems/score/types.h: URL for license changed.
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
