path: root/cpukit/score/cpu/m32c/include/rtems/score/cpuatomic.h (follow)
* m32c: Remove this targetSebastian Huber2018-11-121-14/+0
| | | | Update #3599.
* Remove make preinstallChris Johns2018-01-251-0/+14
