Rename Priority_bit_map_Control in Priority_bit_map_Word.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
Add proper license and copyright.
Add CPU port specific per-CPU control.
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
architectures. SMP atomic port will be later.
This is the result of a sed script which converts all uses
of @{ into a consistent form.
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an
integer literal that can be used by the assembler. This value will be
used to calculate offsets of structure members. These offsets will be
used in assembler code.
The size of a pointer is part of the application binary interface (ABI)
and thus independent of the actual programming language. The compiler
will provide defines to determine the current ABI. We use these defines
to select the appropriate CPU_SIZEOF_POINTER value.
Static assertions in the new file "cpukit/score/src/percpuasm.c" will
ensure that the value of CPU_SIZEOF_POINTER is consistent with the
current compiler settings. Also the offset values used by assembler
code are verfied.
for details.
PR 1956/cpukit
* rtems/score/cpu.h: Correct multiple alignment constants. Improve
comments.
PR 1954/cpukit
* score/cpu/lm32/rtems/score/lm32.h: Protect against macro expansion.
PR 1955/cpukit
* rtems/score/cpu.h: Convert CPU_swap_u16 into a static inline.
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
PR 1868/lm32
* irq.c: Bugfix.
* cpu.c: Remove /*PAGE markers which were interpreted by a long dead
print script.
* Makefile.am: Reformat.
PR 1777/cpukit
* libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c,
score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c,
score/inline/rtems/score/thread.inl, score/src/heapfree.c,
score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c:
Consolidated access to _Thread_Dispatch_disable_level.
* score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c:
New files.
* cpu.c, irq.c, rtems/score/lm32.h:
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1697/cpukit
* rtems/score/cpu.h: lm32 really needs aligned stack. Recent changes
highlighted that this macro was incorrect.
* rtems/score/lm32.h: Add lm32_read_interrupts().
PR 1599/cpukit
* irq.c: Rename _Context_Switch_necessary to _Thread_Dispatch_necessary
to more properly reflect the intent.
PR 1635/cpukit
* rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority
handling, to isolate the bitmap implementation of priorities in the
supercore so that priority management is a little more modular. This
change is in anticipation of scheduler implementations that can
select how they manage tracking priority levels / finding the highest
priority ready task. Note that most of the changes here are simple
renaming, to clarify the use of the bitmap-based priority management.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
PR 1573/cpukit
* irq.c, rtems/score/cpu.h: Add a per cpu data structure which contains
the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* irq.c: Change _exception_stack_frame into void*.
* rtems/score/cpu.h: Remove warning in _CPU_Context_Initialize.
* rtems/score/cpu.h: Make _gp global.
* cpu.c, cpu_asm.S, irq.c: Add include of config.h
* cpu.c: Provide body for CPU specific Idle thread. This halts on qemu
but is just a nop on a real cpu.
* cpu_asm.S, irq.c, rtems/score/cpu.h: Add lm32 gdb stub support.
* cpu.h: corrected the registers in Context_Control and
in CPU_Interrupt_frame to correspond to the saved frame in cpu_asm.S
Also switched on CPU_ISR_PASSES_FRAME_POINTER.
* cpu_asm.S: Moved the restore part of _CPU_Context_switch for
easier reading. Fixed _CPU_Context_restore, it now moves the
argument and branches to a label in _CPU_Context_switch. Removed
unnecessary saves of registers in context switch and irq handling.
Rewrote irq code to call the C helper. Added some documentation
* irq.c: New file derived from c4x and nios2.
* cpu_asm.S: We cannot use any other register than r0 without saving
them to the stack. (_ISR_Handler clears r0 right at the beginning)
* cpu.c, rtems/score/cpu.h: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
