The MAIR index currently assigned (1) for uncached memory segments is
not configured properly for this purpose. Instead, this switches
uncached memory segment flags to MAIR index 2 which is properly
configured for uncached inner and outer shareable domains.
This alters the AArch64 page table generation and mapping code and MMU
configuration to use page table level 0 in addition to levels 1, 2, and
3. This allows the mapping of up to 48 bits of memory space and is the
maximum that can be mapped without relying on additional processor
extensions. Mappings are restricted based on the number of physical
address bits that the CPU supports.
This moves the AArch64 MMU memory type definitions into cpukit for use
by libdebugger since remapping of memory is required to insert software
breakpoints.
