* | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-14 | 1 | -213/+0 |
| | | | | | | | | | | | | AMD a29k declared obsolete. * cpu/Makefile.am: Removed reference. * cpu/a29k/.cvsignore, cpu/a29k/ChangeLog, cpu/a29k/Makefile.am, cpu/a29k/amd.ah, cpu/a29k/asm.h, cpu/a29k/configure.ac, cpu/a29k/cpu.c, cpu/a29k/cpu_asm.S, cpu/a29k/pswmacro.ah, cpu/a29k/register.ah, cpu/a29k/sig.S, cpu/a29k/rtems/.cvsignore, cpu/a29k/rtems/score/.cvsignore, cpu/a29k/rtems/score/a29k.h, cpu/a29k/rtems/score/cpu.h, cpu/a29k/rtems/score/cpu_asm.h, cpu/a29k/rtems/score/types.h: Removed. | ||||
* | 2000-09-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-09-22 | 1 | -2/+18 |
| | | | | | | * amd.ah, cpu.c, cpu_asm.S, register.ah, sig.S, rtems/score/cpu.h: Updated and fixed minor things. Commented out offensive assembly and made applications link. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1998-12-14 | 1 | -0/+197 |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. |
