AMD a29k declared obsolete.
* cpu/Makefile.am: Removed reference.
* cpu/a29k/.cvsignore, cpu/a29k/ChangeLog, cpu/a29k/Makefile.am,
cpu/a29k/amd.ah, cpu/a29k/asm.h, cpu/a29k/configure.ac,
cpu/a29k/cpu.c, cpu/a29k/cpu_asm.S, cpu/a29k/pswmacro.ah,
cpu/a29k/register.ah, cpu/a29k/sig.S, cpu/a29k/rtems/.cvsignore,
cpu/a29k/rtems/score/.cvsignore, cpu/a29k/rtems/score/a29k.h,
cpu/a29k/rtems/score/cpu.h, cpu/a29k/rtems/score/cpu_asm.h,
cpu/a29k/rtems/score/types.h: Removed.
* rtems/score/cpu.h: Filled in something that was marked XXX.
* rtems/score/a29ktypes.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
This was tracked as PR91.
* rtems/score/a29k.h, rtems/score/cpu.h: Switched to using
cpuopts.h not targopts.h to reduce dependency on BSP.
* amd.ah, cpu.c, cpu_asm.S, register.ah, sig.S, rtems/score/cpu.h:
Updated and fixed minor things. Commented out offensive assembly
and made applications link.
* Makefile.am, cpu_asm.S, psmacro.ah, rtems/score/cpu.h:
First attempt to compile with GNU tools. Minor modifications
to compile enough to get to assembler errors.
_Interrupt_Manager_initialization.
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
