Update #3059.
Update #3059.
Update #3056.
Check that no ask help request is registered during unblock and yield
scheduler operations. There is no need to ask for help if a scheduled
thread yields, since this is already covered by the pre-emption
detection.
Update #2556.
Update #2858.
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
Update #2556.
Delete _Scheduler_Thread_change_resource_root() and
_Scheduler_Thread_change_help_state().
Update #2556.
Update #2556.
Update #2423.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Update #2556.
This makes it possible to add scheduler nodes to structures defined in
<rtems/score/thread.h>.
Update #2556.
Add _Thread_queue_Surrender() to unify the mutex surrender procedures
which involve a thread queue operation.
The thread priority is manifest in two independent areas. One area is
the user visible thread priority along with a potential thread queue.
The other is the scheduler. Currently, a thread priority update via
_Thread_Change_priority() first updates the user visble thread priority
and the thread queue, then the scheduler is notified if necessary. The
priority is passed to the scheduler via a local variable. A generation
counter ensures that the scheduler discards out-of-date priorities.
This use of a local variable ties the update in these two areas close
together. For later enhancements and the OMIP locking protocol
implementation we need more flexibility. Add a thread priority
information block to Scheduler_Node and synchronize priority value
updates via a sequence lock on SMP configurations.
Update #2556.
The _RBTree_Find() is no longer used in the score. Move it to sapi and
make it rtems_rbtree_find(). Move corresponding types and support
functions to sapi.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
By convention, thread priorities must be integers in RTEMS. Smaller
values represent more important threads.
Provide dedicated seize and surrender methods for inherit priority
mutexes. This eliminates CORE_mutex_Attributes.
Close #2695.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Delete now unused Objects_Locations.
Update #2555.
Update #2555.
Added only for evaluation purposes. We have to compare the performance
against the ticket lock on the interesting platforms via
smptests/smplock01.
The following GCC shortcoming affects the MCS lock:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=66867
Start with a copy of the Priority SMP scheduler implementation.
Update #2510.
Delete __RTEMS_DO_NOT_INLINE_CORE_MUTEX_SEIZE__ as a preparation to
restructure the CORE mutex variants and reduce the branch complexity.
This function is not used in the score.
Update #2555.
Update #2555.
Update #2555.
Update #2555.
Update #2555.
Update #2555.
Update #2555.
Change _Thread_queue_Flush() into a macro that invokes
_Thread_queue_Do_flush() with the parameter set defined by
RTEMS_MULTIPROCESSING. For multiprocessing configurations add the
object identifier to avoid direct use of the thread wait information.
Use mp_ prefix for multiprocessing related parameters.
Rename Thread_queue_Flush_callout to Thread_queue_MP_callout since this
type will be re-used later for other operations as well.
This field was only by the monitor in non-multiprocessing
configurations. Add new field Thread_Wait_information::remote_id in
multiprocessing configurations and use it for the remote procedure call
thread queue.
Add _Thread_Wait_get_id() to obtain the object identifier for debug and
system information tools. Ensure the object layout via static asserts.
Add test cases to sptests/spthreadq01.
Use an ISR lock to protect the spinlock state. Remove empty attributes.
Update #2555.
The CPU time used of a thread was previously maintained per-processor
mostly during _Thread_Dispatch(). However, on SMP configurations the
actual processor of a thread is difficult to figure out since thread
dispatching is a highly asynchronous process (e.g. via inter-processor
interrupts). Only the intended processor of a thread is known to the
scheduler easily. Do the CPU usage accounting during thread heir
updates in the context of the scheduler operations. Provide the
function _Thread_Get_CPU_time_used() to get the CPU usage of a thread
using proper locks to get a consistent value.
Close #2627.
This simplifies the handling with local-only objects.
Update #2555.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
Make rtems_initialize_data_structures(),
rtems_initialize_before_drivers() and rtems_initialize_device_drivers()
static. Rename rtems_initialize_start_multitasking() to
rtems_initialize_executive() and call the registered system
initialization handlers in this function. Add system initialization API
available via #include <rtems/sysinit.h>. Update the documentation
accordingly.
This is no functional change, only the method to call the existing
initialization routines changes. Instead of direct function calls a
table of function pointers contained in the new RTEMS system
initialization linker set is used. This table looks like this (the
actual addresses depend on the target).
nm *.exe | grep _Linker | sort
0201a2d0 D _Linker_set__Sysinit_begin
0201a2d0 D _Linker_set__Sysinit_bsp_work_area_initialize
0201a2d4 D _Linker_set__Sysinit_bsp_start
0201a2d8 D _Linker_set__Sysinit_rtems_initialize_data_structures
0201a2dc D _Linker_set__Sysinit_bsp_libc_init
0201a2e0 D _Linker_set__Sysinit_rtems_initialize_before_drivers
0201a2e4 D _Linker_set__Sysinit_bsp_predriver_hook
0201a2e8 D _Linker_set__Sysinit_rtems_initialize_device_drivers
0201a2ec D _Linker_set__Sysinit_bsp_postdriver_hook
0201a2f0 D _Linker_set__Sysinit_end
Add test sptests/spsysinit01.
Update #2408.
Update #2408.
