* | cpukit/rtems/src/[s-z]*.c: Change license to BSD-2 | Joel Sherrill | 2022-02-28 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | rtems: Canonicalize Doxygen @file comments | Sebastian Huber | 2020-12-02 | 1 | -3/+5 |
| | | | | | | Use common phrases for the file brief descriptions. Update #3706. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | score: Static Objects_Information initialization | Sebastian Huber | 2018-12-14 | 1 | -81/+5 |
| | | | | | | | | | | | Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621. | ||||
* | score: Remove bogus thread object name support | Sebastian Huber | 2018-10-29 | 1 | -3/+1 |
| | | | | Update #2514. | ||||
* | rtems: Avoid Giant lock for rtems_task_delete() | Sebastian Huber | 2016-05-20 | 1 | -2/+22 |
| | | | | Update #2555. | ||||
* | rtems: Use thread state lock for signals | Sebastian Huber | 2016-05-12 | 1 | -47/+1 |
* | rtems: Remove task variables | Sebastian Huber | 2016-05-04 | 1 | -87/+5 |
| | | | | | Update #2494. Update #2555. | ||||
* | score: Simplify _Objects_Initialize_information() | Sebastian Huber | 2016-04-21 | 1 | -4/+0 |
| | | | | | | Remove unused supports_global parameter. Convert _Objects_Initialize_information() to a macro to avoid use of RTEMS_MULTIPROCESSING define for each caller. | ||||
* | Use linker set for Classic User Tasks init | Sebastian Huber | 2016-02-03 | 1 | -16/+0 |
| | | | | Update #2408. | ||||
* | Optional POSIX Keys initialization | Sebastian Huber | 2016-02-03 | 1 | -6/+0 |
* | Optional Classic Tasks initialization | Sebastian Huber | 2016-02-03 | 1 | -1/+10 |
* | rtems: Fix warning | Sebastian Huber | 2016-01-08 | 1 | -1/+0 |
* | score: Initialize thread control to zero | Sebastian Huber | 2015-12-15 | 1 | -15/+0 |
| | | | | This reduces the code size of the thread initialization. | ||||
* | score: Untangle thread actions | Sebastian Huber | 2015-12-11 | 1 | -1/+1 |
| | | | | | | | Remove the thread action handler parameter from _Thread_Action_initialize() and instead set it later in _Thread_Add_post_switch_action(). This avoids a dependency on the thread action handler via the thread initialization. | ||||
* | score: Introduce Thread_queue_Heads | Sebastian Huber | 2015-07-23 | 1 | -4/+2 |
| | | | | | | | | | | | | | Move the storage for the thread queue heads to the threads. Each thread provides a set of thread queue heads allocated from a dedicated memory pool. In case a thread blocks on a queue, then it lends its heads to the queue. In case the thread unblocks, then it takes a free set of threads from the queue. Since a thread can block on at most one queue this works. This mechanism is used in FreeBSD. The motivation for this change is to reduce the memory demands of the synchronization objects. On a 32-bit uni-processor configuration the Thread_queue_Control size is now 8 bytes, compared to 64 bytes in RTEMS 4.10 (other changes reduced the size as well). | ||||
* | Disable deprecated warning on implementation of deprecated methods | Joel Sherrill | 2015-03-17 | 1 | -1/+13 |
* | score: Implement fine-grained locking for events | Sebastian Huber | 2015-03-05 | 1 | -2/+0 |
| | | | | | | | Use the ISR lock of the thread object to protect the event state and use the Giant lock only for the blocking operations. Update #2273. | ||||
* | rtems: Fix ASR SMP support | Sebastian Huber | 2014-05-07 | 1 | -3/+14 |
| | | | | Initialize the ISR lock only once and destroy it properly. | ||||
* | score: Simplify thread control initialization | Sebastian Huber | 2014-04-15 | 1 | -36/+4 |
| | | | | | | | | | | | The thread control block contains fields that point to application configuration dependent memory areas, like the scheduler information, the API control blocks, the user extension context table, the RTEMS notepads and the Newlib re-entrancy support. Account for these areas in the configuration and avoid extra workspace allocations for these areas. This helps also to avoid heap fragementation and reduces the per thread memory due to a reduced heap allocation overhead. | ||||
* | Disable per task variables when SMP is enabled | Joel Sherrill | 2014-04-04 | 1 | -13/+28 |
| | | | | | | Per task variables are inherently unsafe in SMP systems. This patch disables them from the build and adds warnings in the appropriate documentation and configuration sections. | ||||
* | score: Thread life cycle re-implementation | Sebastian Huber | 2014-03-31 | 1 | -12/+17 |
| | | | | | | | | | | | | | | | | | | | The thread deletion is now supported on SMP. This change fixes the following PRs: PR1814: SMP race condition between stack free and dispatch PR2035: psxcancel reveals NULL pointer access in _Thread_queue_Extract() The POSIX cleanup handler are now called in the right context (should be called in the context of the terminating thread). http://pubs.opengroup.org/onlinepubs/009695399/functions/xsh_chap02_09.html Add a user extension the reflects a thread termination event. This is used to reclaim the Newlib reentrancy structure (may use file operations), the POSIX cleanup handlers and the POSIX key destructors. | ||||
* | rtems: Use thread action for signals | Sebastian Huber | 2014-03-31 | 1 | -1/+3 |
* | rtems: Include missing header file | Sebastian Huber | 2014-03-18 | 1 | -1/+2 |
* | POSIX keys now enabled in all configurations. | Joel Sherrill | 2014-03-07 | 1 | -1/+6 |
| | | | | | | | Formerly POSIX keys were only enabled when POSIX threads were enabled. Because they are a truly safe alternative to per-task variables in an SMP system, they are being enabled in all configurations. | ||||
* | score: Merge tod implementation into one file | Sebastian Huber | 2013-07-26 | 1 | -1/+0 |
| | | | | | Delete TOD_MICROSECONDS_PER_SECOND, TOD_MICROSECONDS_TO_TICKS() and TOD_MILLISECONDS_TO_TICKS(). | ||||
* | score: Create object implementation header | Sebastian Huber | 2013-07-26 | 1 | -1/+0 |
| | | | | | | Move implementation specific parts of object.h and object.inl into new header file objectimpl.h. The object.h contains now only the application visible API. | ||||
* | score: Create threadq implementation header | Sebastian Huber | 2013-07-26 | 1 | -1/+0 |
| | | | | | | | | Move implementation specific parts of tqdata.h, threadq.h and threadq.inl into new header file threadqimpl.h. The threadq.h contains now only the application visible API. Delete tqdata.h. | ||||
* | score: Create states implementation header | Sebastian Huber | 2013-07-26 | 1 | -1/+0 |
| | | | | | | Move implementation specific parts of states.h and states.inl into new header file statesimpl.h. The states.h contains now only the application visible API. | ||||
* | score: Merge sysstate API into one file | Sebastian Huber | 2013-07-24 | 1 | -1/+0 |
* | rtems: Create tasks implementation header | Sebastian Huber | 2013-07-23 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of tasks.h and tasks.inl into new header file tasksimpl.h. The tasks.h contains now only the application visible API. | ||||
* | rtems: Create event implementation header | Sebastian Huber | 2013-07-23 | 1 | -0/+1 |
| | | | | | | Move implementation specific parts of event.h, event.inl, eventset.h and eventset.inl into new header file eventimpl.h. The event.h contains now only the application visible API. | ||||
* | rtems: Create asr implementation header | Sebastian Huber | 2013-07-23 | 1 | -0/+1 |
| | | | | | | Move implementation specific parts of asr.h and asr.inl into new header file asrimpl.h. The asr.h contains now only the application visible API. | ||||
* | rtems: Add signal post switch extension on the fly | Sebastian Huber | 2012-12-05 | 1 | -50/+0 |
* | score: Add API extensions post switch list | Sebastian Huber | 2012-12-05 | 1 | -4/+7 |
| | | | | | | | | Move post switch hook from API_extensions_Control to new API_extensions_Post_switch_control. Rename _API_extensions_Run_postswitch() in _API_extensions_Run_post_switch(). Add _API_extensions_Post_switch_list and _API_extensions_Add_post_switch(). | ||||
* | score misc: Clean up Doxygen #12 (GCI 2012) | Alex Ivanov | 2012-12-02 | 1 | -23/+7 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/8025203 | ||||
* | score: Add and use <rtems/score/userextimpl.h> | Sebastian Huber | 2012-11-22 | 1 | -1/+1 |
| | | | | | This file contains the parts of <rtems/score/userext.h> that are only necessary for the RTEMS implementation. | ||||
* | rtems: Add system events | Sebastian Huber | 2012-10-30 | 1 | -0/+2 |
| | | | | | | | System events are similar to normal events. They offer a second set of events. These events are intended for internal RTEMS use and should not be used by applications (with the exception of the transient system event). | ||||
* | rtems: Reusable event implementation | Sebastian Huber | 2012-10-30 | 1 | -2/+2 |
| | | | | Change event implementation to enable reuse for system events. | ||||
* | rtems: Remove unused event_condition member | Sebastian Huber | 2012-10-30 | 1 | -1/+0 |
* | 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-05 | 1 | -1/+1 |
| | | | | * rtems/src/tasks.c: Fix typos. | ||||
* | 2011-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-02 | 1 | -5/+5 |
| | | | | | | | | | * rtems/src/tasks.c: Make _RTEMS_tasks_Create_extension, _RTEMS_tasks_Start_extension, _RTEMS_tasks_Delete_extension, _RTEMS_tasks_Switch_extension, _RTEMS_tasks_Post_switch_extension static. * score/src/scheduleredf.c: Make _Scheduler_EDF_RBTree_compare_function static. | ||||
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -14/+7 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | ||||
* | 2009-09-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-26 | 1 | -3/+3 |
| | | | | | | * libmisc/capture/capture.c, posix/src/pthread.c, rtems/src/tasks.c, score/include/rtems/score/userext.h: Eliminate use of deprecated rtems_extension. Re-add prototype for _User_extensions_Add_API_set. | ||||
* | 2009-07-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-03 | 1 | -1/+3 |
| | | | | | | | * itron/src/task.c, posix/src/pthread.c, rtems/src/tasks.c, sapi/src/exinit.c, score/include/rtems/score/apiext.h, score/src/apiext.c: No APIs currently implemented use the predriver_hook so disable it until such time as it is used. | ||||
* | 2009-01-21 Nickolay Kolchin <nbkolchin@gmail.com> | Joel Sherrill | 2009-01-21 | 1 | -2/+0 |
| | | | | | | | Joel Sherrill <joel.sherrill@oarcorp.com> PR 1357/cpukit * rtems/src/tasks.c: Ensure creating a task with no ASR is honored. | ||||
* | 2009-01-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-01-21 | 1 | -0/+1 |
| | | | | * rtems/src/tasks.c: Initialize event_condition to 0 just because. | ||||
* | Eliminate TRUE/FALSE. | Ralf Corsepius | 2009-01-06 | 1 | -2/+2 |
