brains GmbH.
This function was declared, however, a definition was missing. Add a
validation test for it.
Threads may join the thread termination of another thread using the
pthread_join() or rtems_task_delete() directives. The thread cancel operation
used a special case priority boosting mechanism implemented by
_Thread_Raise_real_priority(). The problem was that this approach
* is not transitive,
* does not account for priority adjustments of the calling task
while waiting for the join,
* does not support clustered scheduling, and
* does not detect deadlocks.
All these problems are fixed by using a priority inheritance thread queue for
the join operation.
Close #4679.
The uniprocessor schedulers had some special case logic for the
PRIORITY_PSEUDO_ISR priority. Tasks with a priority of PRIORITY_PSEUDO_ISR
were allowed to preempt a not preemptible task. If other higher priority task
are made ready while a PRIORITY_PSEUDO_ISR task preempts a not preemptible
task, then the other tasks run before the not preemptible task. This made the
RTEMS_NO_PREEMPT mode ineffective.
Remove the PRIORITY_PSEUDO_ISR special case logic. This simplifies the
uniprocessor schedulers. Move the uniprocessor-specific scheduler support to
the new header file <rtems/score/scheduleruniimpl.h>.
Close #2365.
Use early returns to simplify rtems_scheduler_ident().
Change license to BSD-2-Clause according to file history.
Update #3053.
Updates #4625.
Updates #3053.
Updates #3053.
Move all rtems_scheduler_* directives to the new header file
<rtems/rtems/scheduler.h>. Add a Scheduler Manager API and
implementation group.
Remove the THREAD_WAIT_STATE_READY_AGAIN and simply use the initial value to
indicate that a thread does not wait on something. Rename
THREAD_WAIT_FLAGS_INITIAL to THREAD_WAIT_STATE_READY. This change is necessary
so that _Thread_Continue() can be called for threads which never waited on
something (for example dormant threads).
Update #4546.
Return an error status for the following error condition in
rtems_scheduler_remove_processor():
While an attempt is made to remove a processor from a scheduler, while
the processor is the only processor owned by the scheduler, if a thread
exists which uses the scheduler as a helping scheduler, then the
processor shall not be removed.
The reason is that ask for help requests and withdraw node requests are
processed asynchronously in any order. An ask for help request carried
out on a scheduler without a processor is undefined behaviour.
Update error status description.
Update #4544.
These external functions rtems_scheduler_get_processor() and
rtems_scheduler_get_processor_maximum() which may be used by bindings
for languages other than C/C++.
Do not write to the object referenced by old_priority in error paths.
This is in line with other directives.
We have to use a second thread queue context to acquire and release the
thread wait lock.
Close #4356.
This patch set replaces the CPU budget algorithm enumeration with a set of CPU
budget operations which implement a particular CPU budget algorithm. This
helps to hide the CPU budget algorithm implementation details from the general
thread handling. The CPU budget callouts are turned into CPU budget
operations. This slightly reduces the size of the thread control block.
All schedulers used the default scheduler tick implementation. The tick
scheduler operation is removed and the CPU budget operations are directly used
in _Watchdog_Tick() if the executing thread uses a CPU budget algorithm. This
is performance improvement for all threads which do not use a CPU budget
algorithm (default behaviour).
The rate monotonic period statistics were affected by
rtems_cpu_usage_reset(). The logic to detect and work around a CPU
usage reset was broken.
The Thread_Contol::cpu_time_used is changed to contain the processor
time used throughout the entire lifetime of the thread. The new member
Thread_Contol::cpu_time_used_at_last_reset is added to contain the
processor time used at the time of the last reset through
rtems_cpu_usage_reset(). This decouples the resets of the CPU usage and
the rate monotonic period statistics.
Update #4528.
Set the postponed jobs count to zero in rtems_rate_monotonic_cancel() so that
rtems_rate_monotonic_get_status() returns a consistent status for inactive
periods.
Update #4511.
Adjust parameter names to match with the declaration. This avoid using
a name reserved by the C standard: "time".
Close #4035.
Close #2548.
The rtems_rate_monotonic_get_status() directive returns an arbitrary
number for the count of postponed jobs if it is called for a newly
created period object. Set the count of postponed jobs to zero during
object creation.
Close #4511.
This simplifies the implementation a bit. Declare _TOD_Days_to_date[] in
<rtems/score/todimpl.h>. Make _TOD_Days_per_month[] and
_TOD_Days_since_last_leap_year[] static.
Update #4338.
Split up the multi line if statement into smaller parts.
Replace call to removed _Partition_Free() with a call to _Objects_Free().
Use the new Priority_Group_order enum instead of a boolean to indicated if a
priority should be inserted as the first or last node into its priority group.
This makes the code more expressive. It is also a bit more efficient since a
branch in _Scheduler_Node_set_priority() is avoided and a simple bitwise or
operation can be used.
The rtems_partition_return_buffer() wrongly accepted which were exactly
at the buffer area end. Use the buffer area limit address for the range
checking.
Close #4490.
Move common code into _Thread_Exit(). This enables a tail call
optimization in most cases.
If rtems_task_delete() is called from within interrupt context, then
return RTEMS_CALLED_FROM_ISR. This makes the behaviour predictable.
Update #4414.
rtems_task_restart() may be called from within interrupt context. So
checking only that the thread to restart is equal to the executing
thread is insufficient to determine a self restart. We have to also
check that no ISR is in progress. Merge _Thread_Restart_other() and
_Thread_Restart_self() into one _Thread_Restart() since they share a lot
of common code.
Close #4412.
This simplifies rtems_task_restart().
Close #4410.
Replace defines with an enum.
Update #4406.
Add a parameter to _TOD_Validate() to disable the validation of the
ticks member.
There are two reasons for this change. Firstly, in
rtems_task_wake_when() was a double check for time_buffer == NULL (one
in rtems_task_wake_when() and one in _TOD_Validate()). Secondly, the
ticks member is ignored by rtems_task_wake_when(). This was done with a
write of zero to the ticks member and thus a modification of the
user-provided structure. Now the structure is no longer modified.
Using a mask parameter is quite efficient. You just have to load an
immediate value and there are no additional branches in _TOD_Validate().
Close #4406.
This avoids an integer division at runtime.
This patch fixes bug #4403. Directives
* rtems_timer_fire_when()
* rtems_timer_server_fire_when()
* rtems_task_wake_when()
are documented to return RTEMS_INVALID_ADDRESS when their time-of-day
argument is NULL. But actually they return RTEMS_INVALID_CLOCK. To fix
the issue this patch changes _TOD_Validate() to return a
status code instead of just true/false.
Close #4403
Use _Objects_Free_nothing() for rtems_message_queue_construct() to avoid
unreachable code in _CORE_message_queue_Close() in case only
user-provided message buffers are used.
Update #4007.
Rename _Stack_Free_nothing() in _Objects_Free_nothing() to make it
reusable for the message queue buffers.
Update #4007.
In case the processor set is not large enough to contain the processor
set owned by the scheduler return RTEMS_INVALID_SIZE instead of
RTEMS_INVALID_NUMBER. This is more in line with other directives since
the issue is related to the size of an object.
Close #4401.
Check for a NULL processor set pointer.
The allocator mutex is recursive and already used for the task creation
in rtems_timer_initiate_server(). Just use this mutex instead of the
once mutex to serialize the initialization. This avoids a dependency on
condition variables which are not used here.
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _Thread_Dispatch_direct() to avoid generation
of dead code.
This may reduce the code size a bit.
This avoids having conditional statements to get the API-specific status
code.
code.
There is no need to disable thread dispatching to get the affinity of a
task.
code.
Close #4392.
