* libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c,
libi2c/libi2c.h: New files.
* Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a
simple API/library for i2c devices and drivers for i2c 2-byte eeproms
and a ds1621 temperature sensor; API is documented in libi2c.h
* configure.ac: Check for sys/errno.h.
* configure.ac: Let --enable-deprecated default to "no".
* configure.ac: fix evaluating --enable-ada.
* ada/Makefile.am: Use preinstall.am
* ada/preinstall.am: New.
* configure.ac: Remove or32-rtems
* configure.ac: Check for newlib with stdint.h/inttypes.h.
* Makefile.am: Conditionally use external stdint.h/inttypes.h for
newlib.
* configure.ac: Check for external ampolish3.
* configure.ac: Remove LIBSCORECPU.
* itron/Makefile.am, libcsupport/Makefile.am,
libnetworking/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am,
Makefile.am: Split preinstallation rules in to separate
preinstall.am-files.
* itron/preinstall.am, libcsupport/preinstall.am,
libnetworking/preinstall.am, posix/preinstall.am,
rtems/preinstall.am, sapi/preinstall.am,
score/preinstall.am, wrapup/preinstall.am,
preinstall.am: New (Generated from corresponding Makefile.ams).
* configure.ac: Add AM_CONDITIONAL(AMPOLISH3)-stub.
* configure.ac: Add new header guard to cpuopts.h.
* Makefile.am: Add libfs, libblock, ftpd header install rules.
* libfs/Makefile.am, libblock/Makefile.am, ftpd/Makefile.am: Remove
* Makefile.am: Add include/rtems/tar.h.
Merge-in header rules from libmisc/Makefile.am
* libmisc/Makefile.am: Remove header rules.
Remove lib-specific CPPFLAGS.
* configure.ac: Add checks for <tar.h>
PR 756/rtems
* ftpd/ftpd.c, ftpd/ftpd.h, ftpd/Makefile.am: New (relocated from
/c/src/libnetworking/ftpd)
* ftpd/ftd.h: New header guards.
* ftpd/Makefile.am: Install libftd.a, install ftp.h to rtems/ftp.h.
* configure.ac: Add ftpd/Makefile.
* Makefile.am: Add ftpd.
* configure.ac: Remove RTEMS_USES_INTTYPES_H. Require inttypes.h.
* include/rtems/stdint.h: Remove "wild guesses", require inttypes.h.
* libcsupport/include/inttypes.h: Cleanup.
* libcsupport/include/stdint.h: Cleanup.
* include/sys/_stdint.h: Various changes.
Add *leastN_t types. Add INTN_{MIN|MAX} macros.
Add doxygen preamble.
* include/sys/_inttypes.h: Add doxygen preamble.
* libcsupport/include/stdint.h: Add doxygen preamble.
* libcsupport/include/inttypes.h: Add doxygen preamble.
* configure.ac: Add doxygen preamble to cpuopts.h.
* configure.ac: Remove -ansi (Cygwin breaks with it).
* libcsupport/include/stdint.h: Use sys/_stdint.h to setup fixed
size types.
* libcsupport/include/sys/_inttypes.h: Add SCN*N macros.
* configure.ac: Remove RTEMS_CPUOPT([RTEMS_MULTILIBS],..).
(Unused).
* configure.ac: Add score/cpu/no_cpu/Makefile.
* configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README,
librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am,
score/include/rtems/score/mppkt.h: i960 obsoleted and all references
removed.
* configure.ac: Add score/cpu/avr/Makefile.am.
* score/cpu/Makefile.am: Add avr.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
* configure.ac: Rework stdint.h/inttypes.h support.
Add RTEMS_USES_STDINT_H. Add RTEMS_USES_INTTYPES_H.
Remove NEED_STDINT_H. Remove NEED_INTTYPES_H.
Remove termios-flag detection.
* libcsupport/Makefile.am: Install include/stdint.h and
include/inttypes.h for NEWLIB only.
* libcsupport/include/stdint.h: Rework; Now newlib specific.
* libcsupport/src/termios.c: Make newlib specific.
* include/rtems/stdint.h: Rework; Now wrapper to <stdint.h>.
* aclocal/rtems-cpu-subdirs.m4: Remove (Unused).
* configure.ac: Remove RTEMS_CPU_SUBDIRS([score/cpu]).
Add RTEMS_CHECK_SYSV_UNIX.
Add score/cpu/*/Makefile.
* score/cpu/Makefile.am: Add DIST_SUBDIRS.
* configure.ac: Add AC_CHECK_SIZEOF([CPU_CONTEXT]..).
Add SIZEOF_CPU_CONTEXT to cpuopts.h.
Add RTEMS_PROG_CCAS.
* acinclude.m4: Use unquoted "here" document to propagate $3 to
cpuopts.tmp.
* backward/confdefs.h: New.
* Makefile.am: Add backward/confdefs.h.
Add conditional DEPRECATED.
* configure.ac: Add --enable-deprecated.
PR 561/rtems
* include/rtems/concat.h: New.
* Makefile.am: Add include/rtems/concat.h.
PR/589 rtems
* Makefile.am: Add include/rtems/pci.h.
* Makefile.am: Include automake/compile.am.
* configure.ac: RTEMS_TOP([..],[]).
* aclocal/rtems-top.m4: Remove PROJECT_ROOT.
Prepend ../ to $1.
* aclocal/env-rtemscpu.m4: Reworked.
* configure.ac: RTEMS_TOP([.]).
* configure.ac: Requires automake >= 1.8.1.
* configure.ac, aclocal/enable-bare.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/multi.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(deprecated in autoconf-2.59)
* automake/local.am: Remove clean-local, depend-gcc.
* automake/amcompile.am: New.
* configure.ac: Add subdir-objects, AM_PROG_CC_C_O.
* configure.ac: Reflect having removed
libnetworking/libc/Makefile.am, libnetworking/lib/Makefile.am.
* configure.ac: Reflect changes to libmisc/*.
* configure.ac: Reflect changes to libfs Makefile.ams.
* configure.ac: Use here-documents to generate cpuopts.tmp.
Various fixes and changes to argument processing.
Reflect changes to librpc Makefile.ams.
* acinclude.m4: Use here-documents to generate cpuopts.tmp.
* aclocal/check-itron.m4: Remove HAS_IRON_API.
* aclocal/check-multiprocessing.m4: Remove HAS_MP.
* aclocal/check-posix.m4: Remove HAS_POSIX_API.
* configure.ac: Use RTEMS_INLINES instead of USE_INLINES.
Elimimate INLINESdir.
* aclocal/enable-inlines.m4: Ditto. Remove RTEMS_USE_MACROS.
* .cvsignore: Add config.h.in.
* configure.ac: Make RTEMS_DEBUG an RTEMS_CPUOPT.
* wrapup/Makefile.am: Reflect having removed libnetworking/wrapup.
* configure.ac: Ditto.
* acinclude.m4: New.
* configure.ac: Don't use AUTOHEADER to generate cpuopts.h.
Add local autoheader config.h.
* aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST.
* aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
* aclocal/check-posix.m4: Add m4-quotes.
Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* aclocal/canonical-host.m4: Remove.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* aclocal/sysv-ipc.m4: Remove reference to RTEMS_CANONICAL_HOST.
* aclocal/canonical-target-name.m4: Use AC_CANONICAL_HOST instead of
AC_CANONICAL_TARGET. Use $host instead of $target.
* aclocal/check-multiprocessing.m4: Add m4-quotes.
Remove RTEMS_CHECK_CPU.
* aclocal/check-itron.m4: Add m4-quotes.
* aclocal/check-networking.m4: Add m4-quotes.
* aclocal/check-cpu.m4: Remove.
* aclocal/canonical-target-name.m4: Add m4-quotes.
* configure.ac: Merge-in former aclocal/check-cpu.m4.
* configure.ac: Check for sys/cdefs.h.
* aclocal/env-rtems-cpu.m4: Add project_includedir.
Deprecate PROJECT_INCLUDE. Change project_includedir to
$(PROJECT_ROOT)/include for multilibs.
* configure.ac: Reflect having removed include/Makefile.am and
librpc/include/Makefile.am.
* configure.ac: Removed duplicate entry.
