path: root/configure.in (follow)
* Bare bsp patch from Chris Johns and regenerated files.Joel Sherrill1998-06-251-3/+3
* Added freebsd support from Dario Alcocer <alcocer@connectnet.com>.Joel Sherrill1998-06-181-0/+6
* Regenerated aclocal and configure after cleaning up the check thatJoel Sherrill1998-06-041-27/+14
| | | | a BSP source directory was present to eliminate a chunk of redundant code.
* ppc-rtems is now an alias for powerpc-rtems.Joel Sherrill1998-06-031-2/+2
* hppa1.1 -> hppa1_1 remapping crept back in somehow -- gona again.Joel Sherrill1998-05-221-16/+14
| | | | | | | Bare BSP is now only enabled when explicitly specified. Bare BSP options and variables are clearly named so as to be obviously BSP specific. This should avoid conflicts.
* Added bare bsp from Chris Johns <cjohns@plessey.com.au>.Joel Sherrill1998-05-211-11/+57
* Patch from Ralf Corseipus to fix latent configure problems suddenly triggered:Joel Sherrill1998-05-201-14/+3
| | | | | | | | | | | | | | | | | | | | | | | The breakdown: * CC_FOR_TARGET and CXX_FOR_TARGET were not correctly re-read from autoconf's configuration cache (config.cache) * If <target>-[gcc|g++] was not found while running configure, the config macros tried to use other (wrong) compilers (e.g. cc). Changes: * New RTEMS_PROG_CC macro (aclocal/prog-cc.m4). * New RTEMS_PROG_CXX macro (aclocal/prog-cxx.m4) * Moved a shell script fragment from configure.in to a new m4-autoconf macro (New file: aclocal/tool-prefix.m4) * Minor changes to configure.in I tested it with linux/posix (native gcc/primary libc) and sh-rtems/gensh1 on a linux host and didn't notice any bugs related to the problems mentioned above. There seem to be more bugs with the posix bsp, but I consider them minor as the build run completed successfully. It is just too late for me to attempt to fix them now.
* Support bsp_specs style building for linux and solaris. Improved C++Joel Sherrill1998-05-181-8/+12
| | | | support.
* Fixed bug where posix tests were not being enabled.Joel Sherrill1998-04-271-1/+1
* Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵Joel Sherrill1998-04-141-2/+8
| | | | gcc-target-default.cfg
* Patch from Samuel Tardieu <sam@inf.enst.fr> so the messages printedJoel Sherrill1998-04-031-2/+2
| | | | followed GNU conventions.
* Renamed hppa1_1 to hppa1.1Joel Sherrill1998-03-231-3/+0
* renamed ppc to powerpcJoel Sherrill1998-03-231-3/+0
* Updated so test tools are installed even when --disable-tests isJoel Sherrill1998-02-191-1/+2
| | | | specified. Otherwise a target specific runtest is not installed.
* Ralf Corsepius pushing us farther down the autconf path:Joel Sherrill1998-02-171-0/+1
| | | | | | | | | | "Ladies and Gentlement, we proudly present: a roughly hacked autoconf-ed rtems-glom.in" (:-) BTW, to follow up to the discussion about installation points, rtems-glom in its current shape is an ideal example of a target dependent file. If bsp-specific configure-scripts would exist, it might also be a bsp-dependent file that contains RTEMS_BSP hard-coded (by configure) into it.
* Update from Ralf Corsepius:Joel Sherrill1998-02-171-26/+51
| | | | | | | | | | | | Yep, I have a bunch of bug-fixes and additions pending (Yet another monster patch, ... I can hear you scream :-). 1) configure.in : one AC_CONFIG_HEADER(...) line too much. 5) configure.in: --enable-cpp should probably be renamed to --enable-cxx, as gnu-programs use "cxx" to specify C++ specific configure options, while cpp is used for the preprocessor (e.g egcs uses --with-cxx-includedir, autoconf internally uses $CXX),
* Fixed hppa1.1 configuration.Joel Sherrill1998-02-111-3/+3
* Change suggested by Ralf Corsepius:Joel Sherrill1998-02-041-3/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | I am not sure if this is related to this problem, but here is an observation: All config.sub scripts from rtems' intrastructure packages internally transform i386-rtems into i386-pc-rtems newlib-1.8.0-rtems/config.sub i386-rtems --> i386-pc-rtems egcs-1.0/config.sub i386-rtems ---> i386-pc-rtems egcs-1.0.1/config.sub i386-rtems ---> i386-pc-rtems bintutils-2.8.1.0.19/config.sub i386-rtems ---> i386-pc-rtems gas-98xxxx/config.sub i386-rtems ---> i386-pc-rtems The only exception is rtems itself: rtems/config.sub i386-rtems ---> i386-rtems I am not sure if this influences i386-rtems + c++/posix, but this indicates that rtems' config.sub script should to be updated. To fix this, simply copying config.sub e.g. from egcs and removing all i[3456]-rtems* case statement lines from configure.in should be sufficient. BTW, from autoconf's point of view i386-pc-rtems is the correct target conforming autoconf's naming conventions, but using i386-rtems for all packages (infrastructure and rtems) should make no difference.
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-301-2/+2
* correctionJoel Sherrill1998-01-301-1/+2
* Reverted change ...Joel Sherrill1998-01-221-2/+2
* Corrected/simplified setting of RTEMS_ROOT.Joel Sherrill1998-01-221-2/+2
* Added autoconf support for strerror/sys_errlist per Ralf Corsepius'Joel Sherrill1998-01-211-0/+2
| | | | | direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2.
* Fixed libhwapi to reflect eeprom to non volatile memory rename.Joel Sherrill1998-01-201-7/+7
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-161-0/+3
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Added "done" to end of list of BSPs found.Joel Sherrill1998-01-151-1/+1
* Fixed code for --disable-rtems-inlines so that it would completeJoel Sherrill1998-01-151-1/+12
| | | | | | | configuration successfully. Added code to detect configuring macros and POSIX API at the same time. There is no macro implementation for the POSIX API.
* Made --enable-gcc28 the default.Joel Sherrill1997-12-221-1/+1
* Added size_rtems as a generated file.Joel Sherrill1997-12-221-0/+1
* Changed RTEMS_BSP to RTEMS_BSP_LIST.Joel Sherrill1997-12-161-9/+4
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-101-3/+10
* Redid hwapi makefile search to remove need for -follow option to find.Joel Sherrill1997-12-061-5/+21
| | | | Avoid generating Makefiles for KA9Q and C++ when they are disabled.
* Added better/more correct support for Linux and Solaris simulators.Joel Sherrill1997-12-041-1/+6
* Fixed test for RTEMS_HAS_POSIX_API so the executive POSIX API relatedJoel Sherrill1997-12-011-9/+9
| | | | Makefiles would be properly generated.
* Even more cleanup to make sure all the --enable/disable options avoidJoel Sherrill1997-12-011-22/+68
| | | | | | | generating Makefiles where possible. Added code to make sure make/custom file and bsp directory exist for configured bsps. This code also accounts for "aliased" BSPs.
* Serious cleanup to reduce the number of explicitly listed Makefiles,Joel Sherrill1997-11-301-357/+82
| | | | | eliminated autoconf looking for commands which are unused, and reduce the number of Makefiles generated.
* Changes from Ralf Corsepius (corsepiu@faw.uni-ulm.de) to automaticallyJoel Sherrill1997-11-291-255/+73
| | | | generate the list of Makefiles in the configure script.
* Merged code from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to generateJoel Sherrill1997-11-181-93/+183
| | | | the information in the make/os/XYZ.cfg files using autoconf.
* Added TOD code for MVME162 BSP from Katsutoshi Shibuya.Joel Sherrill1997-10-231-0/+1
* Added termios test.Joel Sherrill1997-10-231-1/+2
* Removed duplicate listing of install in MTARGETS.Joel Sherrill1997-09-211-0/+1
| | | | Add monitor test.
* Use own pdir option was reversed.Joel Sherrill1997-08-261-2/+2
* Added ppc-rtems as alternative name.Joel Sherrill1997-08-041-25/+25
| | | | | Moved files around in list of Makefile's to better support --disable-tests option.
* Corrected typo where "+ " was pasted in from another window.Joel Sherrill1997-08-011-2/+4
| | | | Added c/src/lib/libbsp/m68k/mvme162/consolex/Makefile to list.
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-311-2/+30
| | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
* Added mvme162lx bsp configuration.Joel Sherrill1997-07-091-1/+4
| | | | M68040 FPSP was already part of the tree but was not being built.
* added ka9q stackJoel Sherrill1997-05-271-0/+14
* KA9Q stack removed prior to testing for 4.0.0 public release.Joel Sherrill1997-05-231-14/+0
* updated to correct problem in decoding arguments provided to configure.Joel Sherrill1997-05-221-4/+20
* Added support for Hardware API. This will be distributed as a separateJoel Sherrill1997-04-221-1/+45
| | | | component which can be loaded on top of the RTEMS source tree.
