* startup/bspstart.c: Fixed chip select configuration.
* new-exceptions/bspsupport/ppc_exc_categories.c: Fixed e200 machine
check category.
* configure.ac: Move comment to correct location.
* shared/irq/irq_asm.S: Fix spelling.
* network/network.c: Update for API changes.
* include/u-boot.h: Removed file.
* include/u-boot-config.h, include/tsec-config.h: New files.
* include/bsp.h, start/start.S, startup/bspstart.c: Use new U-Boot
support.
* Makefile.am, preinstall.am: Reflect changes above.
* Makefile.am, preinstall.am, mpc83xx/include/mpc83xx.h,
mpc83xx/network/tsec.c, mpc83xx/network/tsec.h: Make it possible to
use the TSEC driver for other systems.
* mpc83xx/include/mpc83xx.h, mpc83xx/network/tsec.c,
mpc83xx/network/tsec.h: Make it possible to use the TSEC driver for
other systems.
* include/u-boot-config.h: New file.
support.
* shared/uboot_dump_bdinfo.c: Include <bsp/u-boot.h> if necessary.
* shared/include/u-boot-board-info.h: New file.
* shared/include/u-boot.h: Removed file.
* shared/bspgetworkarea.c: Include <bsp/u-boot.h> if necessary.
* shared/include/u-boot.h, shared/src/bsp-uboot-board-info.c: New
files.
* Makefile.am, preinstall.am, startup/start.S: Use standard zero
function.
* startup/linkcmds.base: Reserve enough space for the exception
minimum prologues. Changed start section name.
* startup/bspstart.c: Removed superfluous cache initialization.
* configure.ac: Fixed option default values.
* shared/include/start.h, shared/src/bsp-start-zero.S: New files.
* new-exceptions/bspsupport/ppc_exc_address.c,
new-exceptions/bspsupport/ppc_exc_initialize.c: Fixed IVOR handling for
e200z0 and e200z1.
* mpc55xx/include/mpc55xx.h, mpc55xx/misc/copy.S: Removed zero
functions.
* shared/include/cpuIdent.c, shared/include/cpuIdent.h: Added support
for e500v2. Removed IVPR/IVOR/HWIVOR features since they are included
in Book E.
* new-exceptions/bspsupport/vectors.h,
new-exceptions/bspsupport/ppc_exc.S,
new-exceptions/bspsupport/ppc_exc_categories.c,
new-exceptions/bspsupport/ppc_exc_initialize.c,
new-exceptions/bspsupport/ppc_exc_prologue.c: Added support for
e500v2. Added exception vector defines for Book E types. Removed
e200 exception vector defines. Added e500 exception vector defines.
Unified IVOR calculation for e200 and e500 (e200z1 has hard wired
IVOR values).
minimum prologues.
* mpc83xx/i2c/mpc83xx_i2cdrv.c: Fixed interrupt flag clearing for
MPC55XX family.
* configure.ac: Added I2C options. Fixed eMIOS prescaler. Use
standard linker command file support.
* include/bsp.h: Declare I2C initialization function.
* i2c/i2c_init.c: Implementation.
* make/custom/gwlcfm.cfg, make/custom/mpc5566evb.cfg,
make/custom/mpc55xx.inc: Use standard linker command file support.
* startup/bspstart.c: More board specific settings.
* new-exceptions/bspsupport/ppc_exc.S: Comment.
* new-exceptions/bspsupport/ppc_exc_address.c: Fixed address
calculation for e200z1 core.
* shared/lpc/include/lpc-i2s.h: Documentation. Fixed defines.
* shared/lpc/include/lpc-timer.h: Documentation.
* shared/lpc/network/lpc-ethernet.c: Added support for 10MBit/s links.
* configure.ac, include/bspopts.h.in: More options.
* include/lpc32xx.h: Added watchdog definitions.
* include/mmu.h, misc/mmu.c: Added const qualifier.
* startup/bspreset.c: Use watchdog reset.
* make/custom/rtl22xx_t.cfg: Now compiles.
* bsp_specs, start/start.S, startup/linkcmds: Use linker command base
file.
* bsp_specs, start/start.S, startup/linkcmds.csb337,
startup/linkcmds.csb637: Use linker command base file.
* startup/linkcmds: Use linker command base file.
* start/start.S, startup/linkcmds: Use linker command base file.
* startup/linkcmds, start/start.S: Use linker command base file.
* startup/bspgetworkarea.c: Removed file.
* Makefile.am, bsp_specs, start/start.S, startup/bspstart.c,
libnds/include/nds/jtypes.h, libnds/source/arm9/gurumeditation.c,
libnds/source/common/interruptDispatcher.S,
libnds/source/common/interrupts.c, startup/linkcmds: Use linker
command base file.
* startup/linkcmds.lpc2362, startup/linkcmds.lpc23xx_tli800,
startup/linkcmds.lpc24xx_ea, startup/linkcmds.lpc24xx_ncs_ram,
startup/linkcmds.lpc24xx_ncs_rom_ext,
startup/linkcmds.lpc24xx_ncs_rom_int: Update due to linker command
file changes.
* startup/linkcmds.lpc32xx_mzx, startup/linkcmds.lpc32xx_mzx_stage_1,
startup/linkcmds.lpc32xx_mzx_stage_2,
startup/linkcmds.lpc32xx_phycore: Update due to linker command file
changes.
* shared/startup/linkcmds.base: Split up fast region.
* include/lcd.h, misc/lcd.c: New files.
* misc/io.c, include/io.h: Documentation, bug fixes, more
configurations.
* include/lpc24xx.h: Added DAC and I2S.
* Makefile.am, bsp_specs, preinstall.am, startup/bspstarthooks.c,
file changes.
* include/lpc32xx.h: Added I2S module.
startup/linkcmds.lpc32xx, startup/linkcmds.lpc32xx_mzx,
changes.
* preinstall.am, shared/lpc/include/lpc-i2s.h,
shared/startup/linkcmds.armv4, shared/startup/linkcmds.armv7: New
files.
* Makefile.am: Added header and linker command files intended to be
used by every ARM BSP.
* shared/startup/linkcmds.base: Support for EABI and ARM ELF standard.
* shared/include/linker-symbols.h: Update due to linker command file
changes.
* shared/start/start.S, shared/include/start.h: Renamed entry symbol
from start to _start to avoid namespace conflicts. Update due to
linker command file changes.
* mpc55xx/edma/edma.c: Use rtems_chain_first() and do not directly
access the structure.
PR 1719/cpukit
* shared/start/start.S: Avoid "bx" instruction to support ARMv4 and
below.
* mscan/mscan-base.c: Do not use sleep mode to enter init mode. Do
not wait for sleep mode acknowledge.
PR 1691/bsps
* shared/clock/ckinit.c: The sparc64/shared/clock driver has
a bug that causes nested timer interrupts to not be serviced,
which leads to non-preemptive behavior especially when dispatching
work from the timer ISR.
PR 1691/bsps
* shared/include/traptable.h, shared/start/trap_table.S,
shared/startup/linkcmds: Create a dummy trap table
that jumps to the firmware trap table for default trap handlers.
PR 1691/bsps
* usiii/start/bspinit.S: Create a dummy trap table that jumps
* make/custom/dp2.cfg, startup/linkcmds.dp2: New files.
* Makefile.am, preinstall.am: Reflect change above. Install
<bsp/utility.h>. Install BestComm header files.
* configure.ac: Changed BSP options.
* include/mpc5200.h: Added module structures and register defines.
* bestcomm/bestcomm_api.c, bestcomm/bestcomm_api.h,
bestcomm/bestcomm_glue.c, bestcomm/bestcomm_glue.h,
bestcomm/bestcomm_priv.h, bestcomm/load_task.c,
bestcomm/tasksetup_bdtable.c, bestcomm/task_api/bestcomm_cntrl.h: C++
compatibility. Use special heap to manage the SRAM region. Use
interrupt extension API. Fixed warnings.
* console/console.c: Fixed console registration. Fixed warnings.
Added GPS module registration.
* ide/pcmcia_ide.h: Fixed clock value macros.
* ide/pcmcia_ide.c: Update for BestComm API changes.
DP2 specific initialization. Removed zero loop in PIO receive
function.
* include/bsp.h: Added DP2 variant. Removed obsolete defines.
* include/mscan-base.h, mscan/mscan-base.c: Use volatile qualifier.
Format.
* irq/irq.c: Fixed peripheral interrupt handling.
* network_5200/network.c: Update for BestComm API changes.
* start/start.S: U-Boot fixes.
* startup/cpuinit.c: Enable write-back cache strategy. Added special
memory regions.
* startup/linkcmds.brs5l: Fixed memory size.
* console/console.h, console/console.c, console/config.c,
console/ns16550cfg.c: Removed files.
* console/console-config.c: New file.
* configure.ac: New BSP options.
* include/bsp.h: Use new BSP options.
* network/network.c: Avoid memory leak.
* startup/bspstart.c: Initialize console port table.
* spi/spi_init.c: Update for SD card API changes.
* misc/system-clocks.c: Use define instead of function call to allow
smaller delays.
* rtc/rtc-config.c: Fixed type.
* mpc55xx/include/irq.h: Include missing <bspopts.h>. Format.
* mpc83xx/include/mpc83xx.h, mpc83xx/i2c/mpc83xx_i2cdrv.h,
mpc83xx/i2c/mpc83xx_i2cdrv.c: Changes to use this driver for the
MPC55XX familiy.
* libchip/ide/ata.c: Do not violate chain API.
