Close #3250.
Close #4081.
- Allow the RTEMS_ROOT to be conditionally supplied. This
can be a staging area before being moved to the final
install prefix location.
- Update the default.cfg to use RTEMS_ROOT and to not rely on
the exec_prefix so it's paths can be staged.
- Fix and add the needed configure subs.
Closes #3768
for details.
This reverts commit 621e1c9b74272ff94efec749c6c4a673a7c315e8.
* Makefile.am: Don't generate host.cfg.in.
* Makefile.am, Makefile.inc.in, configure.ac, target.cfg.in: Update to
account for movement of .cfg files.
* Makefile.am: Use '|' as sed-delimiter.
* Makefile.am, configure.ac: Move file generation into Makefile.
* Makefile.am: Install *.cfgs into $(pkgdatadir)/make.
* aclocal/check-itron.m4: New.
* aclocal/enable-inlines.m4: New.
* Makefile.am: Add -I aclocal to ACLOCAL_AMFLAGS.
* target.cfg.in: New, copy of c/make/target.cfg.in.
* configure.ac: Add target.cfg.
* Makefile.am: Add target.cfg.
* Makefile.am: Don't include @RTEMS_BSP@.cfg (unused).
* Makefile.am: Remove RTEMS_BSP.cache generation.
Remove handling custom/*.cfgs.
Remove handling custom/default.cfg.
* configure.ac: Remove handling of custom/*.cfgs.
Remove auto* generated custom/default.cfg.
* custom/Makefile.am: Remove.
* compilers/Makefile.am: Remove.
* compilers/.cvsignore: Remove.
* Makefile.am: Merge-in former */Makefile.ams.
Add more vars to <BSP>.cache.
* configure.ac: Reflect changes above. Cosmetic fixes.
* compilers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Use exec_prefix not prefix.
* Makefile.am: Switch to GNU canonicalized autoconf macros.
that does some cleanup:
* remove c/src/make/main.cfg.in (obsolete, unused) and any reference to it.
* remove RTEMS_BSP_SPECS from c/src/make/custom/default.cfg.in (unused)
All files being effected by this patch are only used when building
RTEMS, therefore this patch should not have any side-effects outside
of the source- rsp. build-tree.
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
This patch addresses a few configuration issues and removes some
duplicate configuration files.
Background:
* some files used in AC_INIT were not unique enough and can lead to
problems if a user plays with configure scripts.
* the Makefile templates are independent of the target/cpu and bsp, so
the bsp dependent versions (c/src/make/Templates) are removed.
patch -p1 < rtems-rc-19990820-3.diff
rm -f c/src/make/Templates
ATTENTION: This patch removes several files and one directory :)
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
