* Makefile.am: Switch to shared routine.
* startup/setvec.c: Removed.
* Makefile.am: Eliminate bsp.am. Cleanup.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am, configure.ac, startup/bspstart.c: Add
bsp_get_work_area() implementation and use more of the BSP
Initialization Framework.
* startup/bspgetworkarea.c, startup/bsppost.c: New files.
* Makefile.am: Rework to avoid .rel files.
* Makefile.am, startup/bspstart.c: Links and runs again.
* console/console-io.c: New file.
* Makefile.am, preinstall.am: You need main() to link all applications.
There is no C++ specific way to link currently.
* Makefile.am, startup/main.c: Now can link with C compiler and not
require C++ compiler to link. The file rtems-ctor.cc is not being
built but if there is a need for C++ code to run on this BSP, then it
will have to be addressed. The simplest solution which might work is
to check the RTEMS system state before calling bsp_start() in main().
* Makefile.am: Add preinstall.am.
* Makefile.am: Merge rtems-ctor.o into libbsp.a.
Fix building rtems-ctor.o and no-ctor.o.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* Makefile.am: Build main.o for !HAS_CXX.
Set EXEEXT = <empty> (Workaround to a bug in automake).
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* shmsupp/Makefile.am: Cosmetics.
shmsupp/Makefile.am: Reflect having moved automake.
that converts the unix directory to automake.
Ralf's note: Please check c/src/lib/libbsp/unix/posix/startup/Makefile.am.
I am not sure if it is correct.
