* cpu.c, cpu_asm.S, irq_stub.S: #include <rtems/powerpc/powerpc.h>.
* cpu.c: Convert to using c99 fixed size types.
* cpu.c, cpu_asm.S: URL for license changed.
PR 288/rtems
* support/new_exception_processing/cpu.c: _ISR_Nest_level is now
properly maintained and does not reside in SPRG0.
PR 356/bsps
* cpu.c: This patch makes RTEMS/PowerPC eabi compliant.
* cpu.c: Currently only the mpc8260 BSP supports interrupt nesting.
NOTE: These needs to be generalized as the patch is applied to other
BSPs.
* cpu.c: Per PR211 fix
saving/restoring floating point context. The fpsave and fprestore
routines are only used in a executing context which _is_ fp and hence
has the FPU enabled. The current behavior required the FPU always to
be on which is very dangerous if lazy context switching is used.
[Joel Note: Some ports explicitly enabled the FPU in the FP save and
restore routines to avoid this.]
The patch also makes sure (on powerpc only) that the FPU is disabled
for integer tasks. Note that this is crucial if deferred fp context
switching is used. Otherwise, fp context corruption may go undetected!
Also note that even tasks which merely push/pop FP registers to/from
the stack without modifying them still MUST be FP tasks - otherwise
(if lazy FP context switching is used), FP register corruption (of
other, FP, tasks may occur)!
Furthermore, (on PPC) by default, lazy FP context save/restore
is _disabled_.
This was tracked as PR91.
* rtems/score/c_isr.inl: Deleted and contents merged into cpu.c.
* cpu.c: Received contents of c_isr.inl.
* Makefile.am: Deleted reference to c_isr.inl.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc8xx/clock/clock.c,
mpc8xx/timer/timer.c, new_exception_processing/cpu.c,
new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S,
old_exception_processing/cpu.c, old_exception_processing/cpu.h,
old_exception_processing/cpu_asm.S, old_exception_processing/rtems.S:
Fixed typo.
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
