Close #3250.
Close #4081.
Remove the BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN hack. The interrupt
stacks are now allocated by the linker.
Update #3459.
Updates #3425.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3387.
upgrade to that version.
Close #3387.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3250.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Several GCC tests faild due to the outdated previous linker command
file.
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
for details.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* tools/.cvsignore, tools/ChangeLog, tools/Makefile.am,
tools/configure.ac, tools/psim-bottom, tools/psim-gdb-bottom,
tools/psim-gdb-top.in, tools/psim-shared, tools/psim-top.in,
tools/runtest-bottom, tools/runtest-top.in: Removed.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* Makefile.am, configure.ac: Disable network interface when networking
is disabled.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* configure.ac: Add fast idle.
* Makefile.am, configure.ac, startup/bspstart.c: Add capability for
bootcard.c BSP Initialization Framework to ask the BSP where it has
memory for the RTEMS Workspace and C Program Heap. These collectively
are referred to as work area. If the BSP supports this, then it does
not have to include code to split the available memory between the
two areas. This reduces the amount of code in the BSP specific
bspstart.c file. Additionally, the shared framework can initialize
the C Library, call rtems_debug_enable(), and dirty the work area
memory. Until most/all BSPs support this new capability, if the BSP
supports this, it should call
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When
the transition is complete, this autoconf macro can be removed.
* configure.ac, startup/bspstart.c: Add BSP_DIRTY_MEMORY option.
* configure.ac: Remove explicit ampolish3 support (now in
RTEMS_BSP_CONFIGURE).
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* configure.ac: Remove argument from RTEMS_PPC_EXCEPTIONS.
* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
PR 581/bsps
* Makefile.am, bsp_specs, configure.ac, include/bsp.h, include/tm27.h,
start/start.S, startup/bspstart.c, startup/linkcmds,
tools/Makefile.am, tools/psim, vectors/vectors.S, wrapup/Makefile.am:
Convert PSIM to new exception model.
* irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: New files.
* startup/setvec.c, timer/timer.c: Removed.
* Makefile.am: Cosmetics.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
vectors/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, vectors/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
Reflect changes to bsp.am.
