* acinclude.m4: Removed vegaplus BSP.
* vegaplus/.cvsignore, vegaplus/ChangeLog, vegaplus/Makefile.am,
vegaplus/bsp_specs, vegaplus/configure.ac, vegaplus/clock/clockdrv.c,
vegaplus/include/.cvsignore, vegaplus/include/bsp.h,
vegaplus/include/registers.h, vegaplus/include/tm27.h,
vegaplus/irq/bsp_irq_asm.S, vegaplus/irq/bsp_irq_init.c,
vegaplus/irq/irq.c, vegaplus/irq/irq.h, vegaplus/start/start.S,
vegaplus/startup/bspstart.c, vegaplus/startup/exit.c,
vegaplus/startup/linkcmds: Removed.
irq/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
wrapup/Makefile.am: Remove.
* irq/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/bsp.h, include/registers.h, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, start/start.S,
startup/bspstart.c, startup/exit.c: URL for license changed.
irq/Makefile.am: Reflect having moved automake.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am, console/Makefile.am, include/Makefile.am,
start/Makefile.am: VPATH was not setup correctly
* Makefile.am, bsp_specs, configure.in, console/Makefile.am,
include/Makefile.am, irq/Makefile.am, irq/irq.c, start/Makefile.am,
startup/Makefile.am, startup/exit.c, wrapup/Makefile.am:
Made to conform to current practice concerning automake and
autoconf. Corrected minor warnings.
* vegaplus BSP submitted by Emmanuel Raguet <raguet@crf.canon.fr> and
Eric Valette <valette@crf.canon.fr>.
* vegaplus/bsp_specs, configure.in, console/Makefile.am,
include/Makefile.am, include/bsp.h, include/registers.h,
irq/Makefile.am, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c,
irq/irq.h, start/Makefile.am, start/start.S, startup/Makefile.am,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
wrapup/Makefile.am: New files.
