> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
- c/src/exec/score/cpu/powerpc/ppc.h: some small changes
(added ppc403 characteristics like a exception vector prefix
register, some special register definitions). I am quite sure, they
are compatible with the existing sources, although I did not check
- c/src/exec/score/cpu/powerpc/cpu.c: There is one severe
limitation in the exception entries: Due to the current code
arrangement, the "branch absolute" to the ISR handler may only
jump to the first 128MByte or the last 128MByte of the 4GByte
address range. When the ppc403 is running out of ROM, the ROM
functions are located in the last 128MByte (0xFFF00000 and up).
These addresses were not handled correctly (sign reduced) in
"install_raw_handler". The change I added should work on existing
ppc BSPs aswell...
ports.
vector number to user ISR's and other ports could pass both the vector
number and a pointer to the ISF.
<td@imd.m.isar.de>.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
part of the Thread Handler. This required the name of the optional
CPU dependent IDLE thread implementation to change.
like signal dispatching.
(andy@i-cubed.demon.co.uk). This initial submission is known
to work on the IBM 403. It is thought to work on the Motorola
601, 603, and 604 although this remains to be tested.
Another user -- Doug Currie (e@flavors.com) -- is interested in
this work and will be testing it on the 604 using the Metrowerks
C compiler and a different format assembly language.
