This fixes commit b678a199e499b6c3f0b453393434aefaee180423 for SMP
configurations.
Move declarations of bsp_interrupt_get_affinity() and
bsp_interrupt_set_affinity() to <bsp/irq-generic.h>. Canonicalize the
<bsp/irq.h> includes.
Implement bsp_interrupt_get_affinity() and bsp_interrupt_set_affinity() only if
needed (usually RTEMS_SMP).
Provide stub implementations for i386 to fix build errors.
The parameters are unused due to API constraints. The functions are
used through function pointers. Alternative implementations may use the
parameters.
Update #4862.
Close #4954.
Simplify leon3_counter_use_irqamp_timestamp().
Update #4954.
Update #4954.
Move code blocks to simplify C preprocessor usage.
Update #4954.
Merge the timecounter and CPU counter support for the leon3 BSP family.
Remove now unused functions from the CPU counter support of the erc32
and leon3 BSPs.
Update #4954.
Share the timecounter instance between the clock and the CPU counter.
This greatly simplifies the clock driver since we have to do the device
selection only in one place, the CPU counter support.
Update #4954.
Using the auto reload counter which generates the clock ticks for the
timecounter or CPU counter is quite difficult and only works in
uniprocessor configurations.
Update #4954.
Enable a BSP-specific CPU counter implementation.
Update #4954.
Update #3707.
Do not wait for other processors to halt.
Update #3706.
Remove the BSP_POWER_DOWN_AT_FATAL_HALT BSP option. Applications should
do the customization of the system termination with an initial fatal
extension.
Move, document, and reformat support functions from <leon.h> to
<bsp/leon3.h>.
Separate the probing of the interrupt controller from the
initialization.
brains GmbH.
The LEON3_Boot_Cpu global object is only used by start.S. Move the definition
of this object to start.S and use a local symbol .Lbootcpuindex for it.
Use a compare-and-swap instruction to assign the boot CPU. This allows a
concurrent initialization.
Close #4845.
This patch changes the license to BSD-2 for all source files where the
copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research.
Some files also includes copyright right statements from OAR and/or
embedded Brains in addition to Gaisler.
Updates #3053.
Updates #4625.
Since the trap table is now statically initialized, there is no need to
invalidate the instruction cache.
Using rtems_interrupt_entry_install() instead of
rtems_interrupt_handler_install() avoids a dependency on the dynamic memory
allocation.
Updates #3937.
Rename LEON3_FATAL_INVALID_CACHE_CONFIG_MAIN_PROCESSOR in
LEON3_FATAL_INVALID_CACHE_CONFIG_BOOT_PROCESSOR since the term
"boot processor" is used elsewhere in the code base.
Take the interrupt force register into account in all configurations.
Update #3269.
Move _CPU_Fatal_halt() declaration to <rtems/score/cpuimpl.h> and make sure it
is a proper declaration of a function which does not return. Fix the type of
the error code. If necessary, add the implementation to cpu.c. Implementing
_CPU_Fatal_halt() as a function makes it possible to wrap this function for
example to fully test _Terminate().
Do not return a status code in bsp_interrupt_facility_initialize() since this
leads to unreachable code in bsp_interrupt_initialize(). Use RTEMS_DEBUG
assertions in bsp_interrupt_facility_initialize() if necessary.
Update #3269.
Return a status code for bsp_interrupt_set_affinity().
Update #3269.
Return a status code for bsp_interrupt_get_affinity().
Update #3269.
Return a status code for bsp_interrupt_vector_disable().
Update #3269.
Return a status code for bsp_interrupt_vector_enable().
Update #3269.
