brains GmbH.
Updates #4625.
Do not return a status code in bsp_interrupt_facility_initialize() since this
leads to unreachable code in bsp_interrupt_initialize(). Use RTEMS_DEBUG
assertions in bsp_interrupt_facility_initialize() if necessary.
Return a status code for bsp_interrupt_vector_disable().
Update #3269.
Return a status code for bsp_interrupt_vector_enable().
Update #3269.
Add a default implementation which just returns RTEMS_UNSATISFIED.
Update #3269.
Add a default implementation which clears the attributes to zero and
just returns RTEMS_SUCCESSFUL for valid parameters.
Update #3269.
Add rtems_interrupt_raise_on() and rtems_interrupt_clear().
Add a default implementation which just returns RTEMS_UNSATISFIED for
valid parameters.
Update #3269.
valid parameters.
Update #3269.
Use BSP_INTERRUPT_VECTOR_COUNT instead of BSP_INTERRUPT_VECTOR_MAX.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
Avoid one level of indirection.
Update #4202.
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64
code.
This breaks out AArch32-specific code so that the shared GICv3 code can
be reused by other architectures.
Statically initialize the ARMv7-M vector table to allow a placement in
ROM with read-only MPU settings.
Change licence to BSD-2-Clause in some files.
At least on GICv1 the interrupts 0 up to including 31 are so called
Peripheral Private Interrupts (PPIs). We have to initialize the
priority of the PPIs on secondary processors.
This adds support for the GICv3 interrupt controller along with the
redistributor to control SGIs and PPIs which wasn't present in GICv2
implementations. GICv3 implementations only optionally support
memory-mapped GICC interface interaction and require system register
access be implemented, so the GICC interface is accessed only
through system registers.
The following variants
* GICv1 with Security Extensions,
* GICv2 without Security Extensions, or
* within Secure processor mode
have the ability to assign group 0 or 1 to individual interrupts. Group
0 interrupts can be configured to raise an FIQ exception. This enables
the use of NMIs with respect to RTEMS.
BSPs can enable this feature with the BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0
define. Use arm_gic_irq_set_group() to change the group of an
interrupt (default group is 1, if BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0 is
defined).
Update #3285.
