path: root/bsps/arm/lpc176x/include/bsp/lpc-gpio.h (follow)
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-081-1/+1
| | | | Update #3706.
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+100
