With this, it is possible to use GPIOs as CS pins in the LPSPI. To avoid
additional complexity, the GPIOs will have the same limitations as the
native (hardware) CS pins.
The GPIO CS feature adds a number of extra code when starting SPI
transfers on this controller. Therefore it is possible to disable the
additional code by just setting the IMXRT_LPSPI_MAX_CS option to 0. In
that case only native CS pins are supported.
At the moment, this feature is only enabled on i.MXRT1166 by default
because it is not tested on i.MXRT1050. But it should work there too.
The mcux_sdk has a different interface for getting the clock for
IMXRT11xx than for getting it in IMXRT10xx. Adapt simple drivers to
support that interface.
brains GmbH.
It wasn't possible to keep the CS line low between multiple message
descriptors in one transfer. This patch reworks the driver so that it is
possible.
Update #4180
This allows an application to get the registers of the LPSPI. That is
usefull for applications that want to use DMA for a very specialized and
highly optimized communication.
Update #4180
Update #4180
