path: root/bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_spi.h (follow)
* bsp/imxrt: Update support library from mcux-sdkChristian Mauderer2023-05-221-0/+719
This imports new files from the mcux-sdk support library. NXP now offers the library as a git repository instead of a zip package. The git repository supports multiple CPUs from the i.MXRT family: https://github.com/nxp-mcuxpresso/mcux-sdk.git The imported files are from revision 2b9354539e6e4f722749e87b0bdc22966dc080d9 This revision is the same as MCUXpresso 2.13.0 with small bug fixes. For importing the files, a script has been used, that parses the mcux-sdk cmake files and creates the yaml files for RTEMS: https://raw.githubusercontent.com/c-mauderer/nxp-mcux-sdk/d21c3e61eb8602b2cf8f45fed0afa50c6aee932f/export_to_RTEMS.py
