* | bsps/imxrt: Adapt to new mcux-sdk version | Christian Mauderer | 2023-05-22 | 1 | -0/+1 |
| | | | | | Remove the old NXP MCUXpresso SDK and adapt the BSP so that it uses the new mcux-sdk. | ||||
* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | bsp/imxrt: Enforce alignment for devicetree | Christian Mauderer | 2022-02-21 | 1 | -1/+1 |
| | | | | | | A device tree binary has to be 8 byte aligned in memory. This is checked since RTEMS commit 34052ef78cf8724dee73e9279b2c6bff8cfed234 "libfdt: Add FDT alignment check to fdt_check_header()". | ||||
* | bsp/imxrt: Add new BSP | Christian Mauderer | 2020-11-20 | 1 | -0/+93 |
Update #4180 |
