path: root/bsp-howto (follow)
* bsp-howto: Mention clock driver hook removalSebastian Huber2018-06-261-22/+1
| | | | Update #3436.
* Update due to BSP source reorganizationSebastian Huber2018-04-2713-355/+74
| | | | | | This patch is a part of the BSP source reorganization. Close #3285.
* bsp-howto: Avoid :file: role with ${...}Sebastian Huber2018-04-231-4/+4
| | | | | | | | The curly braces have a special meaning in the :file: role. This patch is a part of the BSP source reorganization. Update #3285.
* bsp-howto: Update BSP source code structureSebastian Huber2018-04-201-91/+41
* Clarify INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAILSebastian Huber2017-11-201-1/+4
| | | | Update #3239.
* bsp-howto: Add getentropy.Christian Mauderer2017-11-172-0/+40
| | | | Update #3239.
* bsp-howto/console: Move misplaced var. in exampleMartin Erik Werner2017-11-161-1/+1
| | | | Signed-off-by: Martin Erik Werner <martinerikwerner@gmail.com>
* Add indexes to all documents.Chris Johns2017-11-122-2/+5
| | | | Update #3229.
* Shorten BSP and Driver Guide name (missed commit)Joel Sherrill2017-10-121-1/+1
| | | | Updates #3141.
* Shorten the name of the BSP and Device Driver Development GuideJoel Sherrill2017-10-122-4/+4
| | | | | | | | | | | | | Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141.
* bsp-howto: Clock_driver_support_install_isr()Sebastian Huber2017-09-181-3/+5
| | | | Close #3139.
* Update copyright notices.Chris Johns2017-08-111-6/+9
* bsp: Optional clock driver shutdownSebastian Huber2017-08-041-4/+8
* bsp-howto: Warn about TERMIOS_TASK_DRIVENSebastian Huber2017-06-081-0/+2
| | | | Update #2935.
* waf: Cleaner formatting to see the importing.Chris Johns2017-03-271-2/+7
* Use a single top level version number.Chris Johns2017-03-201-4/+5
* Update document titles for consistencyJoel Sherrill2017-01-111-5/+5
* Update Console Driver chapterSebastian Huber2016-12-231-382/+346
| | | | | Close #2785. Close #2838.
* Strip down BSP IntroductionSebastian Huber2016-12-211-49/+13
| | | | Update #2852.
* Add warnings to basic BSP chaptersSebastian Huber2016-12-215-0/+20
| | | | Update #2852.
* Move Shared Memory Support Driver chapterSebastian Huber2016-12-211-1/+1
| | | | | This chapter is very specific. Move it to a less prominent chapter position.
* Move Ada95 Interrupt Support chapterSebastian Huber2016-12-211-1/+1
* Add warning to Timer Driver chapterSebastian Huber2016-12-212-1/+6
| | | | | | Move Timer Driver chapter. Update #2847.
* Add warning to ATA/IDE driver chapterSebastian Huber2016-12-213-2/+16
| | | | Close #2849.
* Remove Non-Volatile Memory Driver chapterSebastian Huber2016-12-212-218/+0
| | | | | | | There exists no standard Non-Volatile Memory Driver in the RTEMS code base. Close #2851.
* Remove Discrete Driver chapterSebastian Huber2016-12-212-191/+0
| | | | | | There exists no standard Discrete Driver in the RTEMS code base. Close #2851.
* Remove Analog Driver chapterSebastian Huber2016-12-212-166/+0
| | | | | | There exists no standard Analog Driver in the RTEMS code base. Close #2850.
* Document I2C frameworkSebastian Huber2016-12-212-0/+20
| | | | Update #2845.
* Document SPI frameworkSebastian Huber2016-12-212-0/+20
| | | | Update #2776.
* Update version/revision to 4.11.99Sebastian Huber2016-12-211-2/+2
* Rework Clock Driver chapterSebastian Huber2016-12-211-100/+137
| | | | Update #2737.
* bsp-howto: Increase the number depth of sections.Chris Johns2016-11-091-1/+1
* bsp-howto: Fix header levels.Chris Johns2016-11-0920-23/+22
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-0323-0/+4656
