* | Add basic DSU support present on GR712RCHEADmaster | Sebastian Huber | 2023-09-29 | 1 | -0/+1 |
| | | | | | Only the time tag counter register is implemented so far. It may be used by clock drivers as a free-running counter to measure time. | ||||
* | Add -extirq option to support simulating the UT700 | Sebastian Huber | 2022-10-26 | 1 | -2/+3 |
* | Support extended interrupts2.29 | Sebastian Huber | 2021-08-04 | 1 | -0/+3 |
* | Added support for RISCV32 systems with CLINT/PLIC | Jiri Gaisler | 2020-12-15 | 1 | -2/+2 |
* | Make grlib IP cores more modular and move them to grlib.c | Jiri Gaisler | 2020-12-01 | 1 | -1017/+51 |
* | Add networking support using host tap device2.23 | Jiri Gaisler | 2020-10-28 | 1 | -7/+13 |
| | | | | | | * Emulation of GRETH 10/100 Mbit MAC and PHY * Supported only on linux | ||||
* | Fix incorrect operation on big-endian hosts | Jiri Gaisler | 2020-02-29 | 1 | -3/+3 |
* | Remove unused variable xcpu | Jiri Gaisler | 2019-11-08 | 1 | -5/+4 |
* | Fix typo that caused cygwin build error | Jiri Gaisler | 2019-11-02 | 1 | -1/+1 |
* | Fix C formatting with indent | Jiri Gaisler | 2019-06-11 | 1 | -107/+122 |
* | Avoid array out of bounds warning on RISC-V | Jiri Gaisler | 2019-06-11 | 1 | -1/+1 |
* | Silence warnings when compiled with LLVM | Jiri Gaisler | 2019-06-11 | 1 | -7/+8 |
* | Made L1 cache optional through --enable-l1cache | Jiri Gaisler | 2019-05-28 | 1 | -22/+71 |
| | | | | | | | * Removed stale config.h * Updated autoconf script with relevant checks * Re-implemented leon3/grlib timer with less events * Bumped version to 2.15 | ||||
* | Standalone sis - initial commit | Jiri Gaisler | 2019-05-14 | 1 | -0/+1151 |
