Close #3250.
Close #4081.
Closes #4040.
Update #3818.
- Add a small memory test config file.
- Update the small memory PowerPC BSPs to use the new test config.
Update #3382
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
Test run performed on T4240 running at 1667MHz in uni-processor
configuration.
Update #2554.
tm02 and tm03 were modified to be reused for multiple configurations
of RTEMS Classic API Semaphores. This added tm31-36. The messages for
tm02 and tm03 were modified to indicate the semaphore attributes.
tm31 - tm36 were added. This resulted in the following cases:
tm02 - rtems_semaphore_obtain: Counting/FIFO not available caller blocks
tm03 - rtems_semaphore_release: Counting/FIFO task readied preempts caller
tm31 - rtems_semaphore_obtain: Counting/priority not available caller blocks
tm32 - rtems_semaphore_release: Counting/priority task readied preempts caller
tm33 - rtems_semaphore_obtain: Binary/FIFO not available caller blocks
tm34 - rtems_semaphore_release: Binary/FIFO task readied preempts caller
tm35 - rtems_semaphore_obtain: Binary/priority not available caller blocks
tm36 - rtems_semaphore_release: Binary/priority task readied preempts caller
Provide a file per BSP to list tests that do not build for a BSP. This change
removes the BSP_SMALL_MEMORY hack from the code. That hack was a
mistake.
Provide configuration files for each BSP with tests that cannot build.
for details.
* Makefile.am, configure.ac: New test for barrier create, ident, and
delete.
* tm30/.cvsignore, tm30/Makefile.am, tm30/init.c, tm30/tm30.doc: New
files.
* Makefile.am: Cleanup.
tm01/Makefile.am: Reflect having moved automake.
tm02/Makefile.am: Reflect having moved automake.
tm03/Makefile.am: Reflect having moved automake.
tm04/Makefile.am: Reflect having moved automake.
tm05/Makefile.am: Reflect having moved automake.
tm06/Makefile.am: Reflect having moved automake.
tm07/Makefile.am: Reflect having moved automake.
tm08/Makefile.am: Reflect having moved automake.
tm09/Makefile.am: Reflect having moved automake.
tm10/Makefile.am: Reflect having moved automake.
tm11/Makefile.am: Reflect having moved automake.
tm12/Makefile.am: Reflect having moved automake.
tm13/Makefile.am: Reflect having moved automake.
tm14/Makefile.am: Reflect having moved automake.
tm15/Makefile.am: Reflect having moved automake.
tm16/Makefile.am: Reflect having moved automake.
tm17/Makefile.am: Reflect having moved automake.
tm18/Makefile.am: Reflect having moved automake.
tm19/Makefile.am: Reflect having moved automake.
tm20/Makefile.am: Reflect having moved automake.
tm21/Makefile.am: Reflect having moved automake.
tm22/Makefile.am: Reflect having moved automake.
tm23/Makefile.am: Reflect having moved automake.
tm24/Makefile.am: Reflect having moved automake.
tm25/Makefile.am: Reflect having moved automake.
tm26/Makefile.am: Reflect having moved automake.
tm27/Makefile.am: Reflect having moved automake.
tm28/Makefile.am: Reflect having moved automake.
tm29/Makefile.am: Reflect having moved automake.
tmck/Makefile.am: Reflect having moved automake.
tmoverhd/Makefile.am: Reflect having moved automake.
* tm01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm18/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmck/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmtests.am: Remove DEFS.
to convert the tmtests directory from Makefile.in to Makefile.am.
