Updates #3053.
The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and
rtems_configuration_is_smp_enabled() were added during the SMP support
development cycle as a workaround to fix some testsuite failures in SMP
configurations. All use cases were replaced with tests for specific
conditions. The configuration option and test macro were undocumented.
Close #3876.
Update #3170.
Update #3199.
Do not use the processor count to determine if SMP is enabled. Instead
use a dedicated configuration option. Enable SMP by default in SMP
configurations.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
PR 1922
* spcbssched02/system.h, spcbssched03/system.h, spedfsched02/system.h,
spedfsched02/task1.c, spedfsched03/system.h: EDF and CBS scheduler:
extern declarations fix.
PR 1923/testing
* spcbssched02/spcbssched02.scn, spcbssched02/system.h,
spcbssched03/init.c, spcbssched03/system.h, spedfsched02/system.h,
spedfsched03/system.h, sprbtree01/init.c: Improve coverage.
PR 1916/testing
* spcbssched02/init.c, spcbssched02/spcbssched02.scn,
spcbssched02/system.h, spcbssched02/task_periodic.c,
spedfsched03/init.c, spedfsched03/system.h,
spedfsched03/tasks_aperiodic.c: Improve coverage.
PR 1897/testing
* Makefile.am, configure.ac: Add tests for Earliest Deadline First
(EDF) Scheduling Algorithm implementation.
* spedfsched01/.cvsignore, spedfsched01/Makefile.am,
spedfsched01/init.c, spedfsched01/spedfsched01.doc,
spedfsched01/spedfsched01.scn, spedfsched01/system.h,
spedfsched01/task1.c, spedfsched02/.cvsignore,
spedfsched02/Makefile.am, spedfsched02/getall.c, spedfsched02/init.c,
spedfsched02/spedfsched02.doc, spedfsched02/spedfsched02.scn,
spedfsched02/system.h, spedfsched02/task1.c, spedfsched03/.cvsignore,
spedfsched03/Makefile.am, spedfsched03/edfparams.h,
spedfsched03/init.c, spedfsched03/spedfsched03.doc,
spedfsched03/spedfsched03.scn, spedfsched03/system.h,
spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c: New
files.
