* | testsuites/sptests/sp[a-h]*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | testsuites/sptests/sp[a-f*]*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 2 | -6/+44 |
* | config: Remove CONFIGURE_DISABLE_SMP_CONFIGURATION | Sebastian Huber | 2020-02-25 | 1 | -2/+0 |
| | | | | | | | | | | The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and rtems_configuration_is_smp_enabled() were added during the SMP support development cycle as a workaround to fix some testsuite failures in SMP configurations. All use cases were replaced with tests for specific conditions. The configuration option and test macro were undocumented. Close #3876. | ||||
* | tests: Use rtems_task_exit() | Sebastian Huber | 2018-10-05 | 2 | -4/+2 |
| | | | | Update #3533. | ||||
* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -22/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | confdefs.h: Add SMP enabled field to configuration | Sebastian Huber | 2017-05-16 | 1 | -0/+2 |
| | | | | | | | | | | | Do not use the processor count to determine if SMP is enabled. Instead use a dedicated configuration option. Enable SMP by default in SMP configurations. Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail otherwise. Update #3001. | ||||
* | sptests misc: Update to not use deprecated methods | Joel Sherrill | 2015-03-17 | 2 | -6/+6 |
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 3 | -2/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 6 | -6/+6 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 7 | -17/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-10-04 Sebastian Huber <sebastian.huber@embedded-brains.de> | Jennifer Averett | 2011-10-04 | 1 | -4/+4 |
| | | | | | | | PR 1922 * spcbssched02/system.h, spcbssched03/system.h, spedfsched02/system.h, spedfsched02/task1.c, spedfsched03/system.h: EDF and CBS scheduler: extern declarations fix. | ||||
* | 2011-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-09-29 | 3 | -0/+12 |
| | | | | | | | | | | | * sp75/init.c, spcbssched01/init.c, spcbssched01/task1.c spcbssched02/init.c, spcbssched02/task_periodic.c, spcbssched03/init.c, spcbssched03/tasks_aperiodic.c, spcbssched03/tasks_periodic.c, spedfsched01/init.c, spedfsched01/task1.c, spedfsched02/getall.c, spedfsched02/init.c, spedfsched02/task1.c, spedfsched03/init.c, spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c, sprbtree01/init.c: Add HAVE_CONFIG_H. | ||||
* | 2011-09-26 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-27 | 1 | -1/+1 |
| | | | | | | | PR 1923/testing * spcbssched02/spcbssched02.scn, spcbssched02/system.h, spcbssched03/init.c, spcbssched03/system.h, spedfsched02/system.h, spedfsched03/system.h, sprbtree01/init.c: Improve coverage. | ||||
* | 2011-09-20 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-20 | 3 | -5/+12 |
| | | | | | | | | PR 1916/testing * spcbssched02/init.c, spcbssched02/spcbssched02.scn, spcbssched02/system.h, spcbssched02/task_periodic.c, spedfsched03/init.c, spedfsched03/system.h, spedfsched03/tasks_aperiodic.c: Improve coverage. | ||||
* | 2011-09-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-09-11 | 1 | -1/+1 |
| | | | | | * spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am: Use all managers. | ||||
* | 2011-09-11 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-11 | 9 | -0/+534 |
PR 1897/testing * Makefile.am, configure.ac: Add tests for Earliest Deadline First (EDF) Scheduling Algorithm implementation. * spedfsched01/.cvsignore, spedfsched01/Makefile.am, spedfsched01/init.c, spedfsched01/spedfsched01.doc, spedfsched01/spedfsched01.scn, spedfsched01/system.h, spedfsched01/task1.c, spedfsched02/.cvsignore, spedfsched02/Makefile.am, spedfsched02/getall.c, spedfsched02/init.c, spedfsched02/spedfsched02.doc, spedfsched02/spedfsched02.scn, spedfsched02/system.h, spedfsched02/task1.c, spedfsched03/.cvsignore, spedfsched03/Makefile.am, spedfsched03/edfparams.h, spedfsched03/init.c, spedfsched03/spedfsched03.doc, spedfsched03/spedfsched03.scn, spedfsched03/system.h, spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c: New files. |
