* | testsuites/smptests/*: Change license to BSD-2 | Joel Sherrill | 2022-04-07 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | smp03: Use floating-point tasks | Sebastian Huber | 2018-01-19 | 1 | -1/+0 |
| | | | | This test uses sprintf(). | ||||
* | smp03: Use floating-point task | Sebastian Huber | 2018-01-19 | 1 | -2/+1 |
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS | Sebastian Huber | 2017-02-14 | 1 | -3/+3 |
| | | | | | | | Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS since the SMP part is superfluous. Update #2894. | ||||
* | Remove CONFIGURE_SMP_APPLICATION | Sebastian Huber | 2017-02-02 | 1 | -1/+0 |
| | | | | | | Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1. Update #2893. | ||||
* | tests/smptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-17 | 1 | -0/+2 |
* | smptests/smp01: Fix semaphore count | Sebastian Huber | 2013-05-27 | 1 | -0/+2 |
| | | | | The locked print needs one semaphore. | ||||
* | 2011-07-29 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2011-07-29 | 1 | -0/+6 |
| | | | | | | | | * smp03/init.c, smp03/system.h, smp03/tasks.c: Modified test to force a task to run prior to starting the next task. This allows the last task to always preempt, where if the tasks started in an odd order the last task could run prior the the task it was supposed to preempt. | ||||
* | 2011-06-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-06-28 | 1 | -0/+68 |
* .configure.ac.swp, ChangeLog, Makefile.am, README, config.h.in, configure.ac, smp01/.cvsignore, smp01/Makefile.am, smp01/init.c, smp01/smp01.doc, smp01/smp01.scn, smp01/system.h, smp01/tasks.c, smp02/.cvsignore, smp02/Makefile.am, smp02/init.c, smp02/smp02.doc, smp02/smp02.scn, smp02/system.h, smp02/tasks.c, smp03/.cvsignore, smp03/Makefile.am, smp03/init.c, smp03/smp03.doc, smp03/smp03.scn, smp03/system.h, smp03/tasks.c, smp04/.cvsignore, smp04/Makefile.am, smp04/init.c, smp04/smp04.doc, smp04/smp04.scn, smp04/system.h, smp04/tasks.c, smp05/.cvsignore, smp05/Makefile.am, smp05/init.c, smp05/smp05.doc, smp05/smp05.scn, smp06/.cvsignore, smp06/Makefile.am, smp06/init.c, smp06/smp06.doc, smp06/smp06.scn, smp07/.cvsignore, smp07/Makefile.am, smp07/init.c, smp07/smp07.doc, smp07/smp07.scn, smp08/.cvsignore, smp08/Makefile.am, smp08/init.c, smp08/smp08.doc, smp08/smp08.scn, smp08/system.h, smp08/tasks.c, smp09/.cvsignore, smp09/Makefile.am, smp09/init.c, smp09/smp09.doc, smp09/smp09.scn: New files. |
