Updates #3053.
Updates #3053.
Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
Update #3382
This test uses sprintf().
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Added status validation.
Rename rtems_smp_get_current_processor() in
rtems_get_current_processor(). Make rtems_get_current_processor() a
function in uni-processor configurations to enable ABI compatibility
with SMP configurations.
Rename rtems_smp_get_processor_count() in rtems_get_processor_count().
Make rtems_get_processor_count() a function in uni-processor
configurations to enable ABI compatibility with SMP configurations.
Add and use _SMP_Get_current_processor() and
rtems_smp_get_current_processor().
Delete bsp_smp_interrupt_cpu().
Change type of current processor index from int to uint32_t to match
_SMP_Processor_count type.
Rename in rtems_smp_get_processor_count(). Always provide
<rtems/score/smp.h> and <rtems/rtems/smp.h>. Add
_SMP_Get_processor_count(). This function will be a compile time
constant defined to be one on uni-processor configurations. This allows
iterations over all processors without overhead on uni-processor
configurations.
The locked print needs one semaphore.
for details.
PR 1589/build
* smp01/Makefile.am, smp02/Makefile.am, smp03/Makefile.am,
smp04/Makefile.am, smp05/Makefile.am, smp06/Makefile.am,
smp07/Makefile.am, smp08/Makefile.am, smp09/Makefile.am: Remove
obsolete optional manager capability.
* smp03/init.c, smp03/system.h, smp03/tasks.c: Modified test to force a
task to run prior to starting the next task. This allows the last
task to always preempt, where if the tasks started in an odd order
the last task could run prior the the task it was supposed to
preempt.
* smp01/init.c, smp02/init.c, smp02/tasks.c, smp03/init.c,
smp03/tasks.c, smp04/Makefile.am, smp04/init.c, smp05/init.c,
smp06/init.c, smp07/init.c, smp08/init.c: Cleaned up tests and fixed
some print statement problems.
* smp04/tasks.c: Removed.
* smp01/smp01.doc, smp02/smp02.doc, smp03/smp03.doc, smp04/smp04.doc,
smp05/smp05.doc, smp07/smp07.doc, smp08/smp08.doc, smp08/system.h,
smp08/tasks.c: Update copyright.
* .configure.ac.swp, ChangeLog, Makefile.am, README, config.h.in,
configure.ac, smp01/.cvsignore, smp01/Makefile.am, smp01/init.c,
smp01/smp01.doc, smp01/smp01.scn, smp01/system.h, smp01/tasks.c,
smp02/.cvsignore, smp02/Makefile.am, smp02/init.c, smp02/smp02.doc,
smp02/smp02.scn, smp02/system.h, smp02/tasks.c, smp03/.cvsignore,
smp03/Makefile.am, smp03/init.c, smp03/smp03.doc, smp03/smp03.scn,
smp03/system.h, smp03/tasks.c, smp04/.cvsignore, smp04/Makefile.am,
smp04/init.c, smp04/smp04.doc, smp04/smp04.scn, smp04/system.h,
smp04/tasks.c, smp05/.cvsignore, smp05/Makefile.am, smp05/init.c,
smp05/smp05.doc, smp05/smp05.scn, smp06/.cvsignore,
smp06/Makefile.am, smp06/init.c, smp06/smp06.doc, smp06/smp06.scn,
smp07/.cvsignore, smp07/Makefile.am, smp07/init.c, smp07/smp07.doc,
smp07/smp07.scn, smp08/.cvsignore, smp08/Makefile.am, smp08/init.c,
smp08/smp08.doc, smp08/smp08.scn, smp08/system.h, smp08/tasks.c,
smp09/.cvsignore, smp09/Makefile.am, smp09/init.c, smp09/smp09.doc,
smp09/smp09.scn: New files.
