path: root/testsuites/samples/Makefile.am (follow)
* Makefile.am: Remove legacy networking filesVijay Kumar Banerjee2021-04-261-23/+0
* samples: Avoid build system defined definesSebastian Huber2019-11-121-5/+5
| | | | Update #3818.
* build: Do not install test programsSebastian Huber2019-01-301-3/+1
* build: Add missing $(LDADD) for dependenciesSebastian Huber2019-01-141-1/+1
* build: Remove local.amSebastian Huber2018-10-101-1/+0
* build: Directly reference libraries in testsSebastian Huber2018-10-101-1/+1
| | | | Remove use of TMPINSTALL_FILES.
* testsuite/samples: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-21/+149
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* testsuite: Add a common test configuration. Fix configure.ac and Makefile.am ↵Chris Johns2017-04-041-7/+13
| | | | | | | | | | | | | | | | | | | | | | | | | | errors. - Add a top level test configuration file for test states that are common to all BSPs. This saves adding a test configuration (tcfg) file for every BSP. - Add the test states 'user-input' and 'benchmark'. This lets 'rtems-test' stop the test rather than waiting for a timeout or letting a benchmark run without the user asking for it to run. - Implement rtems-test-check in Python to make it faster. The shell script had grown to a point it was noticably slowing the build down. - Fix the configure.ac and Makefile.am files for a number of the test directories. The files are difficiult to keep in sync with the number of tests and mistakes can happen such as tests being left out of the build. The test fsrofs01 is an example. Also a there was a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be used. - Fix the test fsrofs01 so it compiles. Closes #2963.
* rtems: Add rtems_interrupt_local_disable|enable()Sebastian Huber2015-06-221-0/+3
| | | | | | | | Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to emphasize that interrupts are only disabled on the current processor. Do not define the rtems_interrupt_disable|enable|flash() macros and functions on SMP configurations since they don't ensure system wide mutual exclusion.
* testsuite: Add a per BSP test check for tests not to build.Chris Johns2014-05-051-8/+8
| | | | | | | | Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* 2007-08-17 Chris Johns <chrisj@rtems.org>Chris Johns2007-08-171-1/+1
| | | | | | | * Makefile.am, README, configure.ac, capture/.cvsignore, capture/Makefile.am, capture/capture.doc, capture/capture.scn, capture/init.c, capture/system.h, capture/test1.c: Add a sample test for the capture engine.
* 2007-04-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-04-021-0/+2
| | | | | | | | * Makefile.am, configure.ac: Convert from Classic API style TOD_Control as fundamental time structure to POSIX struct timespec. Add clock_get_uptime(). * nsecs/.cvsignore, nsecs/Makefile.am, nsecs/init.c, nsecs/nsecs.doc, nsecs/nsecs.scn: New files.
* 2004-01-02 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-021-3/+0
| | | | * Makefile.am: Remove DIST_SUBDIRS.
* 2004-05-10 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-05-101-11/+15
| | | | | | | | | * configure.ac: Add CXX-checks. New conditionals CXXTESTS, MPTESTS, NETTESTS. Add iostream/. * Makefile.am, base_mp/node1/Makefile.am, base_mp/node2/Makefile.am cdtest/Makefile.am, loopback/Makefile.am, pppd/Makefile.am: Reflect changes above. * cdtest/main.cc: Adaptation to new C++ standards.
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-181-1/+1
| | | | * Makefile.am: Reflect having moved aclocal/.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-2/+2
| | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. base_mp/Makefile.am: Reflect having moved automake. base_mp/node1/Makefile.am: Reflect having moved automake. base_mp/node2/Makefile.am: Reflect having moved automake. base_sp/Makefile.am: Reflect having moved automake. cdtest/Makefile.am: Reflect having moved automake. fileio/Makefile.am: Reflect having moved automake. hello/Makefile.am: Reflect having moved automake. loopback/Makefile.am: Reflect having moved automake. minimum/Makefile.am: Reflect having moved automake. paranoia/Makefile.am: Reflect having moved automake. pppd/Makefile.am: Reflect having moved automake. ticker/Makefile.am: Reflect having moved automake. unlimited/Makefile.am: Reflect having moved automake.
* 2003-08-06 Thomas Doerfler<Thomas.Doerfler@imd-systems.de>Jennifer Averett2003-08-061-1/+1
| | | | | | | | PR 369/filesystem * Makefile.am, configure.ac: sample application to show the use of the DOSFS functions * fileio/Makefile.am, fileio/fileio.doc, fileio/init.c, fileio/system.h: New files.
* 2003-04-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-04-291-0/+1
| | | | | * configure.ac: Add pppd. * Makefile.am: Add pppd.
* 2003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-271-1/+4
| | | | | | | | | | | * Makefile.am, configure.ac: Added new test loopback which shows how to use the loopback interface. Thank you Eric Norum for a portable target independent test which exercises the TCP/IP. This should prevent massive failures in the TCP/IP stack from reaching the street. * loopback/.cvsignore, loopback/Makefile.am, loopback/README, loopback/init.c, loopback/loopback.scn: New files.
| | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS. * base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS. * cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS. * hello/Makefile.am: Remove AUTOMAKE_OPTIONS. * minimum/Makefile.am: Remove AUTOMAKE_OPTIONS. * paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS. * ticker/Makefile.am: Remove AUTOMAKE_OPTIONS. * unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-1/+1
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-1/+1
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-271-1/+1
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * sample.am: Remove DEFS.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-2/+1
* Patch rtems-rc-19991117-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-9/+6
| | | | to convert the sample tests to automake.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-4/+4
* New configuration files added by patch fromJoel Sherrill1999-08-101-0/+27
